superchoward |
superchoward Nitrous Nuisance
Posted: 00:02 - 29 Nov 2004 Post subject: How to take bike apart-ish |
I dropped scooter today Silly me, foot got trapped when taking it off stand and then it just fell slowly, teasing me as it inevitably went down. A bit fell out of one of the panel (air scoop grill) Going to fit it again tomorrow but i have to take the panel off to get it on. Whilst i am doing this i thought i would have a mess around with the rest of it see if i can get it to go faster. I just dont want to take it apart, and then not be able to put it back together, anyone know where i can get assembly diagrams or something similar for Peugeot Speedfight 2 WRC 2004 model? Thanks a lot.
Oh one more thing, if i were to take out the copper 'o' ring which is restricting the air flow in the filter, would this make it any faster? If so how much, approximately.
Many Thanks
Chris |
binge |
binge Emo Kiddy
Posted: 00:06 - 29 Nov 2004 Post subject: |
If it is restricted, then I can tell you where all the restrictors are on the Speedfights...
Ive owned and tuned 3 ...
If it is brand new tho, Id strongly advise taking it in to get it done cos if you mess it up, you will regret it.
<|Binge|> ____________________ - Honda XL125S - CBR400 NC29 - VFR400 NC30 - CBR400 NC29 - TL1000R - TeeZeR Pit! - Bandit 12 - YZF450 - LuckyMX125 Pit! - Demon X XLR 140 Pit!
- Honda Chaly 140cc - Thumpstar 190cc 4v MiniSM - Aprilia RS125 Pit-Bike - |
superchoward |
binge |
binge Emo Kiddy
superchoward |
binge |
binge Emo Kiddy
superchoward |
binge |
binge Emo Kiddy
Posted: 01:40 - 29 Nov 2004 Post subject: |
yep, u can put the variator restrictions back in, but i dnt rlly see the point...
have a look at www.beedspeed.com
theres some fitting diagrams on there...
All the best...
<|BiNgE|> ____________________ - Honda XL125S - CBR400 NC29 - VFR400 NC30 - CBR400 NC29 - TL1000R - TeeZeR Pit! - Bandit 12 - YZF450 - LuckyMX125 Pit! - Demon X XLR 140 Pit!
superchoward |
Posted: 01:46 - 29 Nov 2004 Post subject: |
https://www.beedspeed.com/fitting_50cc_variator.htm
That's the one i am looking at, is that right? Is it hard to do? I am a bit of a novice really, just dont wanna bugger it up or get caught by cops. they seem to do lots of randomn stops around my area. Do you know on that diagram i put the link for, just below the top there is an exploded diagram of what seems to be a variator There are lots of numbers pointing to parts, which of these parts do i remove if any to derestrict it?
Chris |
superchoward |
superchoward |
binge |
binge Emo Kiddy
Posted: 17:19 - 29 Nov 2004 Post subject: |
Well there is another way to get your variator off but you have to be very careful...
On the other side of the engine (behind the exhaust) you will have the fan cover/wter pump cover. This depeds on weather its Liquid cooled or air cooled. either way, it makes no different, but on water cooled its not a fan...
Remove the 4 bolts holding the cover on, and you should reveal your flywheel...
Now there are about 4 holes in the fly wheel, If you get a long bolt long enough to fit through one of the holes you can push the bolt in and jam up the cam, this holds the variator still to allow you to remove the nut holding it on... But undo the bolt SLOWLEY so that you dont dammage your engine...
m not sure if the new speedfights are restricted in the air box any more, there might not be a restriction in there...
When you take your variator off, DONT take it apart if you dont know what you are doing... Just simply remove the O rings off the cam shaft and replace the variator and front hub.
Replace the nut and the tighten it up slowley but make sure its tight...
Remember to remove the bolt what you pushed into the fly wheel other wise you will fuck everything up if you try to start it
Replace the fan and cover and put the variator cover kickstart pannel back on and your off...
And then the only other restrictor is the blank hose on the exhaust...
Thats pretty simple to do...
And thats pretty much it...
Good luck mate...
<|Binge|>
"And remember what you are doing is at your own risk, Im not gona be responsible if your bike dont work... But it will" ____________________ - Honda XL125S - CBR400 NC29 - VFR400 NC30 - CBR400 NC29 - TL1000R - TeeZeR Pit! - Bandit 12 - YZF450 - LuckyMX125 Pit! - Demon X XLR 140 Pit!
superchoward |
binge |
binge Emo Kiddy
superchoward |
binge |
binge Emo Kiddy
superchoward |
Posted: 22:33 - 29 Nov 2004 Post subject: |
Right, so, if i buy a pipe such as Leo Vinci ZX or whatever, a performance one which says it has restrictors, it will just be as good as my stock one, therefore for there to be any reason in me buying an exhaust i would need a full on illegal one. If so, which do you recommend. I have no ideas where the rollers go or how to put an exhaust on but i am quite logical so i think i could work out the exhaust, my mate is mechanic anyway. What about the rollers though, where do they go in relation to the variator derestriction bit.
You mind if i have your MSN Messenger address so i can talk to you on there. Might be easier
Chris |
superchoward |
binge |
binge Emo Kiddy
Posted: 23:54 - 29 Nov 2004 Post subject: |
binge69@hot(ive put this gap here so i dont get junk mail )mail.com
Erm, I think your best bet is to go and buy a haynes manual from halfords or wherever. They are £15 and they are really good!
They will show how to set up the variator and put an exhaust on...
As for a restricted race pipe, they have a funnel type cone welded just inside the manifold with a spot weld. Get a hammer and chissel and break the weld, hook it out with a bit of 14 gague wire and you have got yourself a derestricted pipe.
Id recomend going for somthing around £90, I wouldnt go the full hog and get a £250 pipe like mine unles you think an extra 5mph is worth £160 extra...
The variator has a brace on the back of it with 3 screws in, remove the screws, the rollers will fall out in your hand and you will beable to see the 6 slots that they sit in...
Replace the new rollers in (simple as) and put the brace back on, Put the variator back on the cam shaft, then put the spacer lug back on (it slots into the variator) and ur belt, then finally the main front hub/fan... Tighten up the nut and your done...
As for the exhaust, take the stock 1 off (2 nuts on the manifold DO NOT atempt to undo the manifold nuts when the engine is hot)
Remove the 2 bolts on the side of the engine which are holding the rest of the exhaust up (Should be allen key bolts)
the exhaust (with a bit of tuging and twisting) should come off...
Repeat with the new exhaust. And now you have a fully derestricted and stage 1 tuned scooter
superchoward |
Posted: 09:13 - 30 Nov 2004 Post subject: |
Thanks for that Binge. I will see what it is like with the variator restriction off first and then maybe buy an exhaust (most probably) just after Christmas or something. Leo Vince ZX or something i dunno yet.
Ill message you after i have done the variator and tell you if i broke it or not
Chris |
superchoward |
Posted: 19:08 - 30 Nov 2004 Post subject: |
Oooooooops. Friend i took my bike apart with spoke to his college tutor today and his tutor said we were trying to take the clutch off not the variator hahahahaha not sure why i am laughing because it could of ended in tears. Oh well. Least i know now. I am taking it in to college to get it derestricted tomorrow. If the tutor is there anyway. He said that there is a washer in the exhaust that is drilled to increase to flow or something. I thought it was a pipe though that needed to be chopped off. Oh well he knows what he is talking about so maybe it is me not understanding what he meant.
Chris |
superchoward |
Posted: 16:56 - 01 Dec 2004 Post subject: |
Hi binge
yay finally got it derestricted after spendin 1 half hours in friends bakc garden with the variator ponderin which bit to take off and wud it break it or not but we guessed and got it right lol i shit me self when i started it up lol thought it wud just go bang or sumthing works now thou so got 40 out of it might get the exhaust done next dunno thou
thanx binge ill b in touch is it breaks ill b sendin u the bill
lol
chris |
The last post was made 19 years, 147 days ago. Instead of replying here, would creating a new thread be more useful? |
