Brake Drum Pads
AcID ZeR0
PostPosted: 17:00 - 03 Dec 2004    Post subject: Brake Drum Pads Reply with quote
How quickly do the brake drum pads wear down? I haven't had the scoot for long as I brought it second hand at 4021 miles on the clock, With full service history it's now done 4892 miles and the brake lever has to be pulled back quite far before any braking pressure is applied.
Is it normal from drum brakes to wear down quick? I'm aware I can adjust them and I know how to so it's not a real problem just wanted to check.
mr jamez
PostPosted: 17:22 - 03 Dec 2004    Post subject: Reply with quote
If you want drum brakes to be effective then you need to adjust them reguarly, you just need to turn the adjuster tappets, when you spin the wheel there should be contact between the shoes and drum rather than it spinning freely. There might be a cable adjustment as well? not sure have never fiddled with drums on a bike.
Also it doesn't hurt to clean all the dust out of them every once in a while Thumbs Up You can check the brake shoes by taking the drum off, if the studs on the shoes are above the braking matierial iteself then they need replacing, however it would make a horrible shrieking noise if this were the case. Also check that the shoes are not polished/glazed.
Retro-Man
PostPosted: 20:08 - 03 Dec 2004    Post subject: Reply with quote
most bikes with drum brakes have a wear indicator on the hub and an arrow on the hub lever to give and indication on wear.
When I had my old CG I was doing 40 miles a day and had to adjust the brakes at least once a month.
Retro
https://domharnessphotography.webs.com
PostPosted: 22:57 - 03 Dec 2004    Post subject: Reply with quote
The brake shoes last for ever, and they do need adjusting. Still I am surprised that a mere 800 miles makes that much difference.
These can be moved to make the brakes appear better than they are so do not trust them that much.
ZRX61
Victor Meldrew
PostPosted: 02:35 - 04 Dec 2004    Post subject: Reply with quote
adjuster tappets? WTF did you learn that name??? Rolling Eyes
Absolute & total bollocks! There should be NO contact between the shoe & the drum when you spin the wheel.
You adjust the brake so it JUST TOUCHES the drum & then back it off so it's not touching at all but there is barely any travel in the lever to make it touch the drum..
mr jamez
PostPosted: 20:56 - 04 Dec 2004    Post subject: Reply with quote
Haynes manual Laughing
The drums on my mini do not work if I do it like this, probably something wrong with them then Razz
Retro-Man
PostPosted: 11:17 - 05 Dec 2004    Post subject: Reply with quote
your mini brakes have to be adjusted just as you have said.
tighten the square drive all the way so that the brake is locked then back off 1/4 of a turn. this should leave you being able to feel contact between the drum and shoes without the wheel binding.
however bike drum brakes are slightly different in design and require backing off until there is no discernable contact and the wheel spins freely.
Hope this clears up the confusion
Retro
mr jamez
PostPosted: 17:23 - 05 Dec 2004    Post subject: Reply with quote
Cool Thumbs Up at least I know they are ok then.
pipnet11
PostPosted: 23:23 - 05 Dec 2004    Post subject: Reply with quote
Yup exactly right. Brake shoes tend to last bloody ages! My dads BMW has drums and has the same shoes as when it was bought new in 1972! Only about half way through their wear limits. It depends on how soft the pad material is though. at 4000 ish miles I wouldnt worry, theyve got at least another 10,000 in them Id say.
I love the girls that do, I hate the girls that dont, I hate the girls who say they will and then they say they wont, but the girl I like most of all and I think youll say Im right, is the girl who says she never has but looks as though she might. - Max Bygraves
The last post was made 19 years, 145 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.1 - MySQL Queries: 17 - Page Size: 65.66 Kb
