| Blitz_ |
 Blitz_ Two Stroke Sniffer
 Posted: 15:37 - 09 Dec 2004 Post subject: Few riding questions |
May be i should have asked that question in New Bikers forum, but then thought that if i get replies from people like me it wont help me much. So the question is for experienced riders. Generally.
Ok, i've got NSR125RR (2-stroke).
1. When i see the red light quite far ahead and i go around 50mph, is it right that i just press clutch and shift straight from gear i'm in (5th or 6th) down to neutral, and then keep on rolling and brake in the end?
2. Is it right that i generally use my front brake? Most of the time. When i'm supposed to use my rear one?
3. When i stop, which leg i should put down? Cause my instructor (not the CBT guy, the private instructor) told me to put down the right one, so i dont waste time to get into 1st gear off the cross lights?
4. Should i stop in neutral? Or should i hold clutch and be in first gear at crosslights?
I think this is it. Just if have any other advice about gear changing, clutch holding and shifting down, tell me. Cause i think i ride well enough and yeasterday got a bit confused when met AD from this forum and he 've been riding totally different from what i'm used to.
Thanks for help guys,
Ana |
| 8316 |
 8316 Could Be A Chat Bot
 Posted: 15:39 - 09 Dec 2004 Post subject: |
everything seems fine, bar the 1st gear at the lights. snick it into neutral. it doesnt damage your bike like that. you seem ok to me!  ____________________ Now own a Fireblade!! Speed Limits? Bah! |
| nc30 chick |
 nc30 chick Traffic Copper
 Posted: 15:43 - 09 Dec 2004 Post subject: |
Well I only know the way i was taught and that was good enough for me.
You dont have complete control of the bike then, stay in gear till you stop, going down the gears as you slow down. As you are about to come to a stop then put it into 1st.
Your front brake is the most effective, however if its wet then you use both brakes. I was taught to use around 80% front brake and 20% back brake in normal conditions, 50/50 in the wet.
You should put your left foot down so the rear brake is covered at all times, you should already have sorted out your gears.
You should be in first gear ready to go!
Hope this helps
| dainesefreak |
 dainesefreak World Chat Champion
| Rob W |
 Rob W World Chat Champion
 Posted: 15:44 - 09 Dec 2004 Post subject: |
When braking it's best to apply the front brake slightly before the rear, to aviod too much dive and even out the braking, and I'd recommend sticking it in neutral when your at the lights or whatever, I always do. I pretty much always put my right foot down, leave my left sat under the gear lever in case traffic starts moving.
Other than that you seem OK . ____________________ '90 TS50 > '04 Senda 125 > '91 ZXR400 > '90 CB-1 > '04 GSX-R1000 > '96 Bandit 600 > '89 ZXR750 H1 > '96 GSX-R750 SRAD > '98 RR-W Fireblade > '98 T595 Daytona > '03 Hornet 900 > '04 Fireblade > '16 GSX-S1000F (x2) > '23 XSR900 |
| Marc_Buck |
 Marc_Buck Could Be A Chat Bot
| Keith |
 Keith World Chat Champion
| Villers |
 Villers World Chat Champion
 Posted: 15:46 - 09 Dec 2004 Post subject: |
Hi!
Im not an expert but ive been riding about a year now so its not long since I was in the same position as you!
If the lights are a good stretch away it may be best to go down the gears somewhat, but not all the way to first. On my old RS125 If i was in 6th doing 50 towards ared light I would prob drop the box as far as third or second then coast to the line with the clutch in and the bike in 1st. This way if the lights change as you approach you are in a better position to roll on the throttle.
Most braking is done on the front brake, but remember that as your braking you are loading the front which can cause a possible slip in the wet. On damp/wet or greasy roads try feathering the back brake slightly and use the two progressively. If leaned over on a bend and you want to shave of a few mph's use the rear as its possible the front will sit you up! Obviously using the back brake for slower manouvers is better as you have full throttle control and the bike wont nosedive on braking!
I think the guys talking out of his @rse on that one. For my test I was taught that if stationary it was neccessary to cover the back brake in case anything hit you from behind or if you started rolling or something. Basically as a handbrake is in a car. On a 125 I wouldnt bother fighting it into neutral for a short wait at the lights, if you have your left foot down, your right on the brake and your clutch pulled in your ready to go. Once past the test though use your feet as you see fit, if you are turning right on a junction and feel more comfortable leaning the bike right ready for take off, do it!
hope this helps!
| Blitz_ |
 Posted: 15:55 - 09 Dec 2004 Post subject: |
Thnks guys/girls
Thats a pity - i've just got used to ride the way i do and now it is wrong way =(( Now have to get used to put my left foot down, keep the first gear, and steadily slow down...
Ohhh...  |
| Marc_Buck |
| mchaggis |
 mchaggis World Chat Champion
 Posted: 15:59 - 09 Dec 2004 Post subject: |
As far as braking goes, do whatever you feel comfortable with. At the moment anyway, I'm tending to use the front brake hardly at all, unless I need to stop. I use engine braking, changing gears and the rear brake to shave off a little speed if letting off the throttle won't get enough.
If I were on a faster bike and wasn't concerned with just keeping my average speed up and riding smoothly, but riding quickly and stopping suddenly, then perhaps I'd use my front brake more. ____________________ I must not be a troll...
Mmmm, Guinness
Discovering the delights of Hammerite and a 3/4" brush.
| nc30 chick |
| binge |
 binge Emo Kiddy
 Posted: 16:01 - 09 Dec 2004 Post subject: |
When I took my CBT they told me to have left foot on the ground so if another bike or a car comes too close, your right leg is on the bike and out of the way
I see alot if bikers stop at lights, Sort gears out, left foot down and then right foot up ready to go...
<|Binge|> |
| stinkwheel |
 Posted: 16:06 - 09 Dec 2004 Post subject: Re: Few riding questions |
Just to go over it one more time:
| Blitz_ wrote: |
1. When i see the red light quite far ahead and i go around 50mph, is it right that i just press clutch and shift straight from gear i'm in (5th or 6th) down to neutral, and then keep on rolling and brake in the end? |
No. When you see the light, close the throttle, change down through the gearbox as you slow down to always be in a gear which suits your speed. Brake as you come up to the lights and pull in the clutch just before you come to a halt, then change into neutral if necessary (see below) or first.
You should not coast on a motorbike (ie ride along with the clutch pulled in) ever.
| Quote: | 2. Is it right that i generally use my front brake? Most of the time. When i'm supposed to use my rear one? |
The front brake does most of the work on a modern bike, use the back brake along with it to steady the bike. Use the back brake by itself at low speeds or on loose surfaces, it is all too easy to give it too much front which will have you off. You will also fail your test if you use the front brake when doing low speed manouvers such as u-turns.
| Quote: | 3. When i stop, which leg i should put down? Cause my instructor (not the CBT guy, the private instructor) told me to put down the right one, so i dont waste time to get into 1st gear off the cross lights? |
I was always taught to put my left leg down and hold on the back brake with my right which allows a controlled getaway. To me it is a good habit to get into, especially if you get shunted from behind at some lights. Nevertheless, listen to your instructor as he will know what you need to do to pass your test.
| Quote: | 4. Should i stop in neutral? Or should i hold clutch and be in first gear at crosslights? |
Depends how long you can be bothered holding the clutch in for. If you think you will be stopped for a long time, flick it into neutral and save your wrists. Try to anticipate when the lights are going to change so you can be in first and ready to go when they do. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Dan 4RR |
 Dan 4RR World Chat Champion
| jamie192 |
 jamie192 Spanner Monkey
 Posted: 16:49 - 09 Dec 2004 Post subject: |
I would go from experiance as i have only been riding 2 weeks but my cbt instructor answered em all these questions and i remember all his responses.
For this, you can do that no harm in it (from my own experience i find that if i switch right down then the lights change i have ot change back up before setting off or engine breaking almost throwns me over the handle bars)
Use what ever break you like they say you should use 75% front and 25% back but i use my front normally.
Right, here at the lights you should be in first gear holding in the clutch with your back break on so you dont roll, you should have your left foot down on the road ( reason is if a car decides to over take they will do so on the right and if your right legs sticking out its gonna get hit if its tight) u keep the bike in first and hold in the clutch with your back break on.
You will find with some bikes because of bikes gearboxes you cannot always change into neutral easily, sit at the lights in first same thing less hassle and means you dont have to change to set off and saves your right leg. ____________________ Ride Fast, Brake hard, don't fall off! |
| Rob W |
| stinkwheel |
| Villers |
| Rob W |
| Blitz_ |
 Posted: 18:28 - 09 Dec 2004 Post subject: |
Just went to bank in the city and then went for a small ride to try what you all said. Its fine with being in first gear at the traffic jam or at crosslites - much easier to start and stop.
However i didnt like that when you hold the damn clutch, it is impossible to reach out for the indicator switch... Hm How do you sort that out?
Going down through gears is a bit sloooooow... I try not to rush through them now, but can i just switch them down to 2nd in a row holding the clutch and stedily breaking? Cause then its almost the same as release clutch after each change - my speed anyways goes down as it is needed.
Left foot down make me feel a bit weird. Cause then if i wannachange to neutral, i have to put my right foot down, and then change. Feels stupid jusmping on the bike like that...
Just the last questions - why cannot i stand at the crosslights and use my frontbrake? And why i have no control over bike when its in neutral? I can always slip into gear and speed up or break?  |
| Bendy |
 Bendy Mrs Sensible
| mchaggis |
 Posted: 18:38 - 09 Dec 2004 Post subject: |
| Blitz_ wrote: |
Known as the Hendon shuffle, as the technique police riders are/ were apparently taught at the academy. The idea is to always have something on the brakes. Ideally you have your foot brake on as if you get punted up the arse, your hand will tend to lose grip of the front brake.
Something else with this is being able to scratch your arse, wipe your visor, twiddle your mirrors, warm your hands on the engine etc etc. If I'm sat at junctions for a long time, I knock it into neutral, put my foot on the brake, take my hands off the bars and relax. You also need to have your foot on the brake for hillstarts.
| Quote: | Just the last questions - why cannot i stand at the crosslights and use my frontbrake? And why i have no control over bike when its in neutral? I can always slip into gear and speed up or break? |
You can use the front, just it's a matter of what you have control over if you're hit. You have no far less control over the vehicle when it's in neutral, because the only resistance to your motion is the rolling resistance, drag and the gradient, which can speed you up.
The bike will go as fast as it wants to, all you can do is apply the brakes (you're then just on a big weight with wheels). With drive engaged, the bike won't go any faster or any slower than the engine can. Added to that, the engine can be controlled easily with the throttle, so it can force the wheels to turn more slowly just as well as more slowly. ____________________ I must not be a troll...
Mmmm, Guinness
| Fortuna |
 Fortuna World Chat Champion
| r1_lad |
 r1_lad Spanner Monkey
The last post was made 21 years, 255 days ago. Instead of replying here, would creating a new thread be more useful? |
