| DukeRed |
 DukeRed World Chat Champion
 Posted: 21:11 - 21 Dec 2004 Post subject: Need Help Fixing Write Off |
Finally decided to fix the dissasembled NSR in the garage unfortunately I am great at taking things apart (really good!). But am not so good at putting it back together.
As far as I can see the only things wrong with it are:
The front wheel is out of alignment.
The seat frame is slightly bent.
When I try and start it, it just sort of jerks forward a bit and makes weird buzzing sounds.
And all the fairing is totally cracked but that's not important.
How hard are those to fix and any diagnosis for the not starting?
Also is it a tricky conversion to put a standard headlamp on, and where on earth can I put the mirrors and indicators since there are no brackets for them anymore?
Long post but any help appreciated.
Jan ____________________ Enjoy Life There's Plenty of Time to be Dead
https://www.janoner.com |
| Kickstart |
 Kickstart The Oracle
 Posted: 12:27 - 22 Dec 2004 Post subject: |
For the front wheel, undo some of the bolts clamping the forkes to the yokes then bounce the front suspension up and down. As the forks are compressed they will tend to pull themselves back parallel.
For the rear subframe you can try straightening it or get a replacement. Replacement is probably easiest and best.
Check it is out of gear and get it started. Give it plenty of time to warm up and keep the clutch pulled. Hoepfully it will free itself off.
Headlights are easy to get, but the mirrors would be easier. Think there are mounting points for them on the clutch lever bracket / brake master cylinder.
| DukeRed |
 Posted: 13:13 - 22 Dec 2004 Post subject: |
Cheers, that has sorted most of it.
Still can't get it started though. I can't seem to be able to change gears. The clutch cable is still pulling but the gear lever just refuses to move.
Does anyone know where I can get wiring schematics?
| veeeffarr |
 veeeffarr Super Spammer
 Posted: 13:47 - 22 Dec 2004 Post subject: |
| Kickstart |
The last post was made 21 years, 331 days ago. Instead of replying here, would creating a new thread be more useful? |
