Battery terminal nut
Crash it for fun
PostPosted: 21:56 - 19 Dec 2004    Post subject: Battery terminal nut Reply with quote
Hi,
Like a pillock i've managed to lose the rectangular nut from one of the battery terminals on my girlfriends NSR125 (2003). Are these readily available from a garage or do they have to be ordered?
Thanks
Mark
PostPosted: 21:58 - 19 Dec 2004    Post subject: Re: Battery terminal nut Reply with quote
You should be able to use a standard nut, think a fairly standard size should be ok.
Worst case an angle grider should sort it Smile.
gsxrboy
PostPosted: 22:00 - 19 Dec 2004    Post subject: Reply with quote
Standard m6 nut (10mm spanner)
PostPosted: 00:45 - 20 Dec 2004    Post subject: Reply with quote
As above.↑↑↑
If you really want a square one, they do them for woodwork, the thread is the same. You might need to file a little off the sides to make it fit. 10p a dozen in my local hardware store.
binge
Emo Kiddy
PostPosted: 01:59 - 20 Dec 2004    Post subject: Reply with quote
Well ive lost the bolts, and the little square nuts from my battery so ive just got a set of 10mm nut/bolts and they work fine Thumbs Up
jamie192
PostPosted: 11:35 - 21 Dec 2004    Post subject: Reply with quote
If those nuts wont fit in cut a bit off your bolt put it in upside down and put the not on the top instead of in the square bit.
Ride Fast, Brake hard, don't fall off!
The last post was made 21 years, 332 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.27 - MySQL Queries: 14 - Page Size: 46.38 Kb
