| DukeRed |
 DukeRed World Chat Champion
 Posted: 22:07 - 06 Jan 2005 Post subject: Bros Sprockets |
https://predator.bikepics.com/pics/honda-nsr125-01-bikepics-269264.jpg
The guide I have says when the sprocket lines up with the red marking it means the sprocket should be changed. My bike has a green square (as shown).
Also what chain and sprockets fit the bros?
Loads of workshop posts I know but my bike has started to fall apart.
Jan ____________________ Enjoy Life There's Plenty of Time to be Dead
https://www.janoner.com |
| DukeRed |
 Posted: 22:09 - 06 Jan 2005 Post subject: |
And ..... how do you get the front and rear sprocket off?
| K!K @ |
 K!K @ Nova Slayer
 Posted: 01:05 - 07 Jan 2005 Post subject: |
normaly the back sprocket is just a case of taking out the back wheel and undoing the 4-6 nuts that hold the sprocket to the wheel. the front on all my bkes has been a case of taking the faring (if any) off and the casing of the sprocket and then its just been a sir clip holding it on. undo that and it should slide off. Mine fell off .
Good Luck  ____________________ Suzuki AY50 Katana
~Elite~Knights~ |
| DM |
 DM Scooby Slapper
 Posted: 01:44 - 07 Jan 2005 Post subject: |
I noticed I was getting pretty noticeable vibrations throughout the entire bike at high rpm the other week. I got home, checked to see if the wheel alignment was off and discovered that a holding nut had fallen off the rear hub and the other three were very loose . I had secured those metal tabs against them when I was switching sprockets several months ago, but they had worked loose. The list of problems I've had with this bike is endless... |
| stinkwheel |
 Posted: 02:12 - 07 Jan 2005 Post subject: |
Usually if you can pull the chain off the back of the sprocket at the 3 o' clock position or there is significant un and down movement at the same point with the chain correctly tensioned, it is getting on time for a new one. If the teeth are all pointy and hooked over is another giveaway.
Back one as k!k @$$ says. The front one you need to take the sprocket cover off, the sprocket is usually slid over the splined shaft then held in place with a thrust washer which is bolted to the sprocket with two small set-screws.
If you go into any bike shop and ask them to order a chain and sprockets for a Bros, they should keep you right. Pattern ones can be bought from M&P https://www.mandp.co.uk use an o-ring chain. With chain and sprocket kits it is usually a case of more expensive = better. Use a soft link rather than a split link to join the chain, it is a v-twin and will be hard on chains. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| hawkeye |
 hawkeye Nova Slayer
 Posted: 16:36 - 07 Jan 2005 Post subject: |
Because the Bros has a single sided swinger, the rear sprocket is bolted to the lhs of the hub assembly. You have to take a few bits off, but as far as I can remember, it can be done without actually removing the wheel (as the wheel is bolted to the other side/end of the hub  ____________________ '89 R/W/B NC30
'The car in front is... in my way' |
| DukeRed |
 Posted: 18:23 - 07 Jan 2005 Post subject: |
Cheers All. Lots of help.
| WildGoose |
 WildGoose White Van Man
 Posted: 17:06 - 08 Jan 2005 Post subject: |
www.wemoto.com
bros parts should be on the front page, they are the bros specialists so will probly sort you with suitable chain and sprockets
quick delivery too ____________________ So in other words, he stopped you for being flagrantly in posession of a motorcycle in direct contravention of the Hippies, Darkies and People Whose Face I Don't Like The Look of (Police Powers) Act. 1976 |
The last post was made 21 years, 289 days ago. Instead of replying here, would creating a new thread be more useful? |
