scottc1088 |
scottc1088 Renault 5 Driver
Posted: 22:05 - 13 Jan 2005 Post subject: kmx125 wont start |
my kmx 125 wont start, iv just got it off a mate cheap, it has a good spark and very good compression!
but when he had it he set the carb on fire but put it out stright away but the fuel pipes were no good! can someone tell me where the pipes go
also i think fuel is coming out of the overflow(so im told), could this be why its not starting
hope you understand
thanks ____________________ 2000 Derbi Senda R, Malossi 80cc, evolution n.g. full circle race crankshaft,26mm carb,Malossi mhr exhaust,TNT filter,Hebo reedblock + carbon reeds,Alien front light,Kundo 330mm rear shock,13-53
Breaking 2000 senda r |
Posted: 22:31 - 13 Jan 2005 Post subject: |
If fuel is coming out of the overflow either the float is sticking (try gently tapping the side of the carb and see if the fuel flow stops), float height is too high or there is damage to / something in the needle valve.
In your case, it is also possible that the fire could have damaged the folats which are most likley made of plastic. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
scottc1088 |
Posted: 22:33 - 13 Jan 2005 Post subject: |
ill try and check tomorrow to see if fuel is coming out but shouldnt it still run anyway?
my m8 had put a pipe from the overflow to somewhere else on the side of the carb ____________________ 2000 Derbi Senda R, Malossi 80cc, evolution n.g. full circle race crankshaft,26mm carb,Malossi mhr exhaust,TNT filter,Hebo reedblock + carbon reeds,Alien front light,Kundo 330mm rear shock,13-53
scottc1088 |
Frost |
Frost World Chat Champion
scottc1088 |
Posted: 08:05 - 15 Jan 2005 Post subject: |
thats what i was thinkin, ill have a mess around with it 1st tho
if theres spark and compression then its got 2 be the carb right?? ____________________ 2000 Derbi Senda R, Malossi 80cc, evolution n.g. full circle race crankshaft,26mm carb,Malossi mhr exhaust,TNT filter,Hebo reedblock + carbon reeds,Alien front light,Kundo 330mm rear shock,13-53
RascalsCustar... |
RascalsCustar... Scooby Slapper
Posted: 23:23 - 15 Jan 2005 Post subject: |
Blimey. Must be your lucky day. I've got one of those (carb) stripped out on my kitchen table...and another one on another of my other kmx's which'll be i'll be striping tomorrow. Buggered float needle I reckon.
Can take a few pics if it's any help so you know what you're doing with yours, if you decide to strip it?
None of the hoses attached to the carb should go back into it. They should all be exposed to the atmosphere.
Saying that those carbs seem to suffer badly from getting clogged main jets. The one above that I pulled out a kmx that's been standing for months, was caked in gunk. |
scottc1088 |
Posted: 23:29 - 15 Jan 2005 Post subject: |
i stripped it down n cleaned it out earlier 2day
and the casing on the side that says kips on it was leaking fuel????
so i ad a look n there was only half of a gasket so i made one outta card, didnt bother kicking it up just tryed bumping it n it blew loads of petrol, oil n other shit out of the exhasut then started (it starts wiv the kick now tho)
the throttle cables melted n it doesnt return to idle it jus stays where you pulled it to even if you push it back but iv just ordered one of these
thanks for youl help ____________________ 2000 Derbi Senda R, Malossi 80cc, evolution n.g. full circle race crankshaft,26mm carb,Malossi mhr exhaust,TNT filter,Hebo reedblock + carbon reeds,Alien front light,Kundo 330mm rear shock,13-53
scottc1088 |
RascalsCustar... |
RascalsCustar... |
scottc1088 |
Posted: 23:50 - 15 Jan 2005 Post subject: |
ok cheers, shud b ready tuesday ____________________ 2000 Derbi Senda R, Malossi 80cc, evolution n.g. full circle race crankshaft,26mm carb,Malossi mhr exhaust,TNT filter,Hebo reedblock + carbon reeds,Alien front light,Kundo 330mm rear shock,13-53
The last post was made 19 years, 105 days ago. Instead of replying here, would creating a new thread be more useful? |
