| TLMick |
 TLMick L Plate Warrior
| TiN |
 TiN Pocket Tin
 Posted: 11:10 - 16 Jan 2005 Post subject: |
Do you have a Power Commander (or equivalent product) fitted? It sounds like it could be a fueling issue. ____________________ TiN
dotgems.net |
| Kickstart |
 Kickstart The Oracle
| TLMick |
| Kickstart |
 Posted: 11:38 - 17 Jan 2005 Post subject: |
Is the bike standard, or have you got different cans on it or a different full exhaust. Air filters?
All of these will affect the fueling slightly and might well cause a flat spot. In winter the air is colder which can easily result in a weaker mixture on most crude fuel injection systems such as those used on bikes (most car systems will use a MAP sensor or MAF sensor to detect the amount of air going through the throttle, while many bike systems are just mapped off the throttle position).
| kasandrich |
 kasandrich Trackday Trickster
| TLMick |
| Kickstart |
 Posted: 11:30 - 19 Jan 2005 Post subject: |
To me it sounds like it is running slightly lean (and the K&N with pipes probably do make it slightly leaner than standard). However Aus summer weather might well richen it up with the hot air (although I suppose it is possible that Suzuki have set up some kind of compensation for the air temperature which is not quite right).
Probably worth checking things like the fuel filter and the fuel pressure regulator. Most fuel injection systems work by using the fuel pressure regulator to maintain a constant difference in pressure between the fuel and the air in the intakes. This way the amount of fuel injected is pretty much directly proportional to how low the injectors are opened for.
If the fuel filter is seriously blocked then there will be insufficient pressure (there is a fair amount spare), and if the pressure regulator is faulty then it might not maintain the pressure.
Also worth checking the injectors, or possibly chucking in a bottle of injector cleaner (not the best solution but cheap and easy).
The last post was made 21 years, 24 days ago. Instead of replying here, would creating a new thread be more useful? |
