| Dom_ |
 Dom_ Points Mean Prizes
| Dom_ |
| Gazdaman |
 Gazdaman I did a trackday!!!
| Dom_ |
| stinkwheel |
 Posted: 19:33 - 28 Jan 2005 Post subject: |
Sounds like your voltage regulator may be on the way out, or something else on the charging system.
Get a voltmeter and measure Volts DC across the two terminals of the battery. It should be 12v with the engine off. With the engine running it should rise to between 14 and 15volts as you increase the revs, any higher or failure to go this high and you have a problem. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Dom_ |
| stinkwheel |
 Posted: 20:10 - 28 Jan 2005 Post subject: |
They usually come as a regulator/rectifier unit. For most bikes (I know nothing about yours) one from a breakers would be around 30-40 quid. A new one could be well into three figures.
If you are into wiring, the best thing is to fit a superdream reg/rec in place of the original one then you can forget about it. This would take some knowlege of how a charging system and wiring loom is put together though. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| DukeRed |
 DukeRed World Chat Champion
 Posted: 02:11 - 29 Jan 2005 Post subject: |
Indicators are crap, they always stop working and a generally a point of worry.
Rip them off and use hand signals, cleaner looking bike to.  ____________________ Enjoy Life There's Plenty of Time to be Dead
https://www.janoner.com |
| binge |
 binge Emo Kiddy
 Posted: 02:44 - 29 Jan 2005 Post subject: |
Hey! My indicators Look perfectly fine!
And I give peugeot a for putting thought into making the indicators fit in with the bike!
The only time I had trouble was when I decided to be a chav and put Blue bulbs in (which were 5w each) and my standards are (10w each) after a day of my indicators either flashing tripple speed or not flashing but staying on. I returned to standard. But they are the only problems ive EVER had!
Well, On the rear left the wire is soildered straight onto the bulb as the terminal rotted off
https://www.bikechatforums.com/files/pug3.jpg
<|Binge|> |
The last post was made 21 years, 254 days ago. Instead of replying here, would creating a new thread be more useful? |
