Aprilia RS125
MADDOG
PostPosted: 02:56 - 26 Jan 2005    Post subject: Aprilia RS125 Reply with quote
Hi I got a second hand aprilia rs125 harada on an S reg i just got 110 out of it on the way to work then after a 6 hour shift went back set off and all of a sudden the were hugh vibrations so i got it hope and took the fairings off and checked the gaskets and the engine mount but no sign of any problems but its still louder and giving off large vibrations. as anyone got any i dea what it is or had the same experience
Aprilia RS125 Harada. has gone now have a SV650s K5
Are you meant to scrape knee slides or rip them clean off?
Rollins
PostPosted: 01:44 - 27 Jan 2005    Post subject: Reply with quote
Vibrating at what speeds?
If it was, erm, 110, then it's to be expected as it's not designed to go that fast...
"... I wouldn't mind doing 130 up to a T junction, but unfortunately my bike tops out at 120 which is gay..."
2005 CBR600RR
MADDOG
PostPosted: 02:43 - 27 Jan 2005    Post subject: Reply with quote
No it wasn't at 110 and thats not the fastest its been its had faster
it was doing 40 i changed down to go upa hill and started to accelerate when there was like a crack/bang the engine not changed and the whole bike vibrates viciously. it vibrates whilst in neutral and idleing and all other times i've had ppl suggest that i could have blown a piston ring or shook the exhaust off or blown a bearing in the gear box and bent my crank. from that i think its the bearing idea due to the fact that if it were the piston ring it wouldnt even rev if it were the exhaust it shouldn't cause any vibrations and if id have bent the crank shaft it would turn over or be able to be puched whilst in gear. but me being a novice i've no idea what it could be
freestyler_onli
PostPosted: 02:48 - 27 Jan 2005    Post subject: Reply with quote
Mine had a few probs changing from 3rd to fourth- a loud clank and then the revs went apeshit- like 8000 then a clunk and back down to normal revs as if nothing had happened..........
MADDOG
PostPosted: 02:54 - 27 Jan 2005    Post subject: Reply with quote
yeah only it didn't go back to normal i just hope i can fix it before sunday as its got a date with a dyno test although a no power dyno would be a good comparison to a full powered one--- there you go sir we got a 400% increase on torque max BHP and 0-60 time
PostPosted: 17:34 - 27 Jan 2005    Post subject: Reply with quote
How many miles has it done?
Under the clutch casing there are some plastic gears. Some drive the water pump / 2 stroke oil pump, another drives the counterbalancer. The ones for the counterbalancer are a service item (there replacement is specified in the service schedule). My guess is that one of these has stripped its teeth and now the balance shaft is not turning.
I would check this quickly as from the top of my head I cannot remember if you might also have lost drive to the water pump / oil pump (probably not as if so it would have gone bang quite quickly otherwise).
They are not that expensive from memory. M1ke can probably give you a better idea of price.
MADDOG
PostPosted: 00:06 - 28 Jan 2005    Post subject: Reply with quote
cheers guys i'll keep u informed of the progress work starts saturday mornign 6am sharp ( i need it sunday)
tony532
PostPosted: 14:31 - 29 Jan 2005    Post subject: Reply with quote
Shocked
you have had the bike go faster than 110 miles an hour Exclamation
PostPosted: 14:43 - 29 Jan 2005    Post subject: Reply with quote
Indicated I have had mine to 115mph, and also 97mph with a pillion.
The speedo is about as accurate as a secret service report on WMD.
MADDOG
PostPosted: 22:17 - 29 Jan 2005    Post subject: Reply with quote
Wel done and thank you to kickstart
Ok guys I took the cover off of the clutch housing to find the plastic!!!! gear on the counter balance was half on it and half lying on the bottom of the cover so i thought easy i had a spare so ill just stck it on............
thats when it hit me i went to stnd up and cracked my head on the handle bars as i fell to the ground i noticed the timing marking on the crank and first shaft.. not so easy after all all i kneed to know is which one lines up to which thing in the casing. any ideas?
ill post picks of the broken part and the gearing when i get them off ma camera
MADDOG
PostPosted: 22:21 - 29 Jan 2005    Post subject: Reply with quote
if you could reply asap as i need the bike tommorw its got a dyno test booked and i dont want to waste £35 im a student and thats alot of cash to me
loply
PostPosted: 11:58 - 30 Jan 2005    Post subject: Reply with quote
Do you have an RS125 manual? if so i would imagine there is info in there. Search on google for one.
Yamaha SZR660 Caution to the wind, the throttle pinned!
MADDOG
PostPosted: 22:25 - 30 Jan 2005    Post subject: Reply with quote
There is no info in the users manual for the timings of the counter weight alos the maintenance manuals on the net take a couple of days to get to you so i didnt get one...... Solution i nipped up to jordan bikes at leeds and asked the mechanic there he gave me a photocopy of a page in their manual showing the timings and a couple of the difficult steps in the rebuild bit.
so i went home did what it said - problem solved.
The last post was made 21 years, 274 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 79.74 Kb
