Bike wont start
RickHolt
PostPosted: 20:53 - 30 Jan 2005    Post subject: Bike wont start Reply with quote
I bought a GPZ500 the other day. We had to run up and down the road with it a few times before we could get it started. Once running, it was fine.
When the ignition button is pressed, there is just a click sound and nothing more.
What I'd like is a list of things that could be wrong, doesn't have to be detailed, just a simple list.
Obvious one would be the starter motor, but what else could be causing this problem?
BLOFLY 636
PostPosted: 21:19 - 30 Jan 2005    Post subject: Reply with quote
either starter motor brushes are not making good contact with the stator, solenoid is not cutting in properly or a loose or corroded joint between the thumb starter and the relay-solenoid-battery
Those bloody footpegs......they ought to do away with em!
Hex
Party Boy
PostPosted: 21:33 - 30 Jan 2005    Post subject: Reply with quote
Dead Battery
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
Scotsman37
PostPosted: 22:31 - 30 Jan 2005    Post subject: Reply with quote
MY friend had the same problem and had several bike mechanics pondering over it but none of them could finally find out what was wrong with it. The only thing they all could confirm that the bike's battery was fine and including the solenoid and the alternator,etc. One mechanic used to stripping/rebuilding old bikes could start it quite easily by removing the cover to the solenoid and use a LARGE screwdriver with plastic handle and to make a connection across the two points of the solenoid. You MUST be carefull when doing this as to avoid electrocution! So theres a trick you can try with it and see if it makes it start up.
So what we did is to remove the fuel tank to get a better overall look at the wiring throughout the bike and low & behold we find another standard connection block clogged with crap from over the years and we thought we had clean them all earlier on even the fuse box was done, but we were wrong! Cleaned the last remaining connection block with WD40.
Doing the above finaly solved his starter problem and it hasn't re-appeared since then. At least we know what do the next time something like that happens, but a regular clean once or more a year would be even better!
AcIdBuRnZ
PostPosted: 03:28 - 31 Jan 2005    Post subject: Reply with quote
Hex wrote:
Dead Battery
Agreed.
Past: Honda NSR125R >> Kawasaki ER-5a2 >> Kawasaki ZZR-600e1 >> Suzuki GSXR-750Y >> Honda VTR 1000 Firestorm
"Chickity China the Chinese Chicken..."
Scotsman37
PostPosted: 03:57 - 31 Jan 2005    Post subject: Reply with quote
To check if it's the battery you must use a multimeter and do the following but if you don't have one it's a good idea to have one. Maplins sell reasonably cheap ones;
Remember if you're removing the battery first disconnect the '-' cable followed by the '+' cable connection and you do it in reverse when reconnecting it to the bike after recharging/inspecting it.
Set the multimeter to the 0 to 20 volts DC range
Connect the '+' probe followed by the '-' probe to the battery's matching connections
On a 12v battery if the readings taken is below 10v then you need to charge the battery and test the voltage again and double check the liquid level (Electrolyte), but if it still doesn't improve after charging then it is your battery that is knackered otherwise you could try what I said in an earlier post.
kasandrich
PostPosted: 17:02 - 31 Jan 2005    Post subject: Reply with quote
Battery is favourite, take it off and take it to a bike dealer, they'll test it for you. Wink
Richard
CBR1000FM
iCraig
PostPosted: 17:20 - 31 Jan 2005    Post subject: Reply with quote
I hate to tell you but thats the symptoms my GPZ displayed just recently, it turned out to be the Alternator magnets had broken away from the rotor stopping the bike from starting and not charging the battery.
If yours is an A Series GPZ (the one with the 16" wheels and rear drum brake) then it is very likely to be this. Take it too a local mechanic and get it checked out, and whatever you do don't try and get the bike running as it may bump/jump start but this may end up sending bits of the magnet into the engine and that can be very costly!
RickHolt
PostPosted: 22:19 - 01 Feb 2005    Post subject: Reply with quote
Quick reply, hope this makes sence.
Where the wires attatch to the starter motor, there are some washers. One of them is an insulator to stop the wire connecting with the starter motor. Looks like that was the problem :p Everything seems to be working fine now, just haven't got the starter motor back in. Need to take off some case and don't want to do that yet, oil will probably go everywhere.
The last post was made 21 years, 161 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 4.67 - MySQL Queries: 13 - Page Size: 61.3 Kb
