| Fallen Angel |
 Fallen Angel Franny the Nanny
 Posted: 17:03 - 05 Feb 2005 Post subject: :o( Second opinions needed on my apparently F*CKED NS125R |
Right guys - I needs some help and some second opinions please.
As you all know, we de-restricted my NS125R some time ago and then the engine blew up, we think due to not having it re-jetted.
Well, the bike's been away and had a new barrell, piston, gaskets, had the carbs re-jetted the lot, but when the guy brought it back last night, it wasn't idling and just kept cutting out, so he took it away to have another tinker with it. (The total cost for him to do all this was £240).
Now, today, he's just off the phone and has told me, that basically, my bike is fucked as it cannot be de-restricted as it is an NS125R-K model and apprently these cannot be de-restricted as when you take the baffler out of the exhaust, there is nothing left in the exhaust to rebound the air (that might not have been his exact words, I'm a bit bamboozled). He's now had a second opinion and has been informed this isn't the case!
Have any of you ever heard of this? I mean, I know a few of you have de-restricted your NS125R, does anyone know what different it makes mine being an NS125R-K???
He says, the bike will run just now, but is likely to seize up again in a couple of weeks time and that the only way around that is to buy a whole new bottom end and new exhaust.
He also mentioned something about the bearings being fucked and that is what is causing the ratting noise (there's a slight rattle coming from the bike).
Basically, I'm fucking gutted, 'cause it looks like the bike is fucked completely.
Fran
EDIT - I've editted this message slightly from my first post, 'cause since the guy's dropped the bike off, he's updated us on some stuff and I truly believe he's done everything he could. He's now got a bottom-end engine for us for £50! I'm on two minds now as what to do, do I buy this bottom end off him and get my mates to help us swap it over, or do I sell the bike as is? It is working, just keeps cutting out instead of idling! Aaaaargghhh!!!!!  ____________________ I have an asshole tolerance level of -10
www.cliqueyclanmcc.co.uk
www.bebo.com/fallenangelfran
| Scotsman37 |
 Scotsman37 World Chat Champion
 Posted: 17:22 - 05 Feb 2005 Post subject: |
I think you'll find far batter help via this link as it only deals with NSR125 bikes and you can find technical specs too and a step by step guide to derestriction, etc.
https://www.nsr125.com/ |
| Fallen Angel |
 Posted: 17:31 - 05 Feb 2005 Post subject: |
That's the link we used to de-restrict my bike.
My bike is an NS not an NSR, and we're now being told - AFTER WE'VE DE-RESTRICTED IT that it cannot be done!!! ____________________ I have an asshole tolerance level of -10
www.bebo.com/fallenangelfran |
| pipnet11 |
 pipnet11 Brolly Dolly
| sickpup |
 sickpup Old Timer
| Fallen Angel |
 Posted: 17:40 - 05 Feb 2005 Post subject: |
He says he's got this information from a guy who's been racing two strokes for 20 years!
I know absolutely fuck all about motorbike mechanics, but I do know I'm gutted and don't really know what we should do now to be honest!  ____________________ I have an asshole tolerance level of -10
| sickpup |
 sickpup Old Timer
| cagiva gezzer |
 cagiva gezzer World Chat Champion
 Posted: 18:22 - 05 Feb 2005 Post subject: |
Any stroker with a restrictive/baffled/plugged exhaust can be derestricted, but they m ght not run smoothly afterwards if the carb doesn't have enough ajustment on it to compensate for the exhaust flowing more freely.
Did the exhaust look like this?
https://www.nsr125.com/exhaust2.jpg
https://www.nsr125.com/zorstholes.jpg
Did he say which bearings were knackered? Buggered main bearings will cause the crank seal to leak and you will seize it due to air leaking in and it running lean.
If he said the "big end bearing" then you'll have to replace that and thast a hefty price, but derestriction or not it would of needed to be done.
Does it run the same carb as the NRS bikes? PHBH28 at a guess..
I think he is just covering his back as any old stroker can be a pain to set up right.
How did it cut out? Like it was running out of petrol? Choke on? ____________________ "because one stroke isnt enough and four strokes waste two" |
| Fallen Angel |
 Posted: 18:35 - 05 Feb 2005 Post subject: |
Right the guy's come back with the bike and basically, he says the exhaust is fine, but it needs new bottom end bearings!
Eddie said the guy was really nice and apologised, and he was saying he's made no money on this job at all - I could believe that cause it only cost me £240 for all that work and I imagine he's put loads of hours into it.
He was also saying to Eddie that he's spoken to other people about the de-restriction who have told him something completely different, saying the way we've restricted it is fine!
Sooo, it now looks like it needs new bottom end bearings and that will be it - fine and dandy!!!
More fucking money!!!!
This bike is costing more money to fix than it did to bloody buy!!!
Think we'll just get it fixed up and then sell it!!!!!  ____________________ I have an asshole tolerance level of -10
| Fallen Angel |
 Posted: 18:39 - 05 Feb 2005 Post subject: |
| cagiva gezzer |
 Posted: 18:45 - 05 Feb 2005 Post subject: |
Been pricing up the bottom end on mine and its
~£40 for a set of main bearings
~£30 gaskets
~£10 oils
~£20 crank seals
~£100 crank rebuild. (pattern, as a OE con rod kit is £170+.. )
But, its a bitch to pull the engine out and split it all.
Two stokes - The internal parts of the engine should be seen a disposable parts....  ____________________ "because one stroke isnt enough and four strokes waste two" |
| Frost |
 Frost World Chat Champion
 Posted: 18:50 - 05 Feb 2005 Post subject: |
I hope its running on premix after the rebuild.
If it still cuts out add more petrol too the tank. This will lean out the oil/petrol ratio and improve running. The oil and petrol can also seperate if left too long, so shake the tank a bit!
Check it over, something might have been missed. So long as it has fuel, oil, air, compression and a spark, it should run without cutting out. Check the positioning of the throttle slides and make sure the carb's are seated correctly.
You could allways just get it running standard, sell it and buy something else!  |
| alains |
 alains World Chat Champion
| Fallen Angel |
 Posted: 19:32 - 05 Feb 2005 Post subject: |
Nothing in the engine has been changed..
Story goes like this...
We de-restricted it by taking out the exhaust intake.
It worked fine for a few weeks then seized, the reason for this I believe is that we didn't get it re-jetted.
They guy did everything we asked him to, replaced the barrell, piston, gaskets and re-jetted it.
It seemed to work fine, but it wasn't idling, just cutting out when you stopped and there was a slight rattle.
The guy says the rattle is the end bearing and if this is fixed, then all's well basically.
I just don't understand how that would fix the idling issue!!!
Fuck - I wish I was more mechanically minded!!!  ____________________ I have an asshole tolerance level of -10
| Fortuna |
 Fortuna World Chat Champion
| Fortuna |
| alains |
 Posted: 20:48 - 05 Feb 2005 Post subject: |
turn the tap on and let it for a small time . turn off the tap and take off your carb without turning it upside down (by the way , have a look if it's no plate beetween the pipe and the reed valves) without turning it upside down , take off the float chamber without spreading any petrol inside , then mesure the hight (something like 20 to 24 mm) if less than that move down the small leg on the float , but not too much otherwise the valve will not close and petrol will overflow . then look your carb adjustments . you should have : main 145 , idle 45 , power 65 or 70 . prior of that you can order jets from https://www.dellorto.co.uk (£2.95 ex VAT and p&p) . they will ship them to you within 4 days . afterwards clean your air box . adjustments on the pilot screw is thight and 2 1/2 turns unscrewed . idle is set at 1500 rpm after 5 mn running (when the temperature indicator goes in the white) ____________________ the worst day fishing is better than the best day working |
| Keith |
 Keith World Chat Champion
| Fallen Angel |
 Posted: 22:59 - 05 Feb 2005 Post subject: |
Thanks Keith!
And I will run it in smoothly when it's all fixed. I'm meant to do 100 miles before taking it over 6,000rpm's - then change the engine oil!
Does that sound about right? ____________________ I have an asshole tolerance level of -10
| catgate |
 catgate Two Stroke Sniffer
| Kickstart |
 Kickstart The Oracle
 Posted: 23:21 - 05 Feb 2005 Post subject: |
You have derestricted it correctly, as far as is realistically practical on a UK model. Yes it might well need the jetting changed.
To fully derestrict an NS125R you would need the complete engine from a full power bike to get the mechanical power valve. Not worth it and they work fairly well without it.
I agree with Cagiva Geezer that it sounds like the main or big end bearings are shot. These are not that expensive (~£30 for the bearings and seals), but are not that easy to fit. As above if the main bearings are worn they damage their seals and allow air in causing the bike to run lean. It would be entirely possible to fit a complete bottom end to replace the current one, and might well be a cheaper and easier option for £50 if you can do the work yourself, but you need to be certain that it is better than the one you already have.
£240 is a fair amount. From David Silver spares a barrel and piston are £99, and I would doubt that it has cost him £140 for a couple of gaskets (head gasket is the expensive one, and that is £10). Doing a top end rebuild is a gentle afternoons work, so probably 1~2 hours for a professional mechanic.
The NS uses a 26mm Dellorto PHBH carb, slightly smaller than that used on the NSR.
The engine oil on a 2 stroke only affects the clutch and gearbox, which from what you have said he has not changed. As such it seems dubious that he is telling you to change it after 100 miles. However I would expect to do rather more than 100 miles before taking it over 6000rpm, probably nearer 300~500.
| alains |
| Fortuna |
| Whitetrash |
 Whitetrash Banned
| Whitetrash |
 Whitetrash Banned
The last post was made 20 years, 363 days ago. Instead of replying here, would creating a new thread be more useful? |
