| Author |
| bish777 |
 bish777 World Chat Champion
 Posted: 10:25 - 08 Feb 2005 Post subject: Biking on a budget - Any tips?? |
Got any tips on biking on the cheap?
Heres a things,
Mr sheen is great for polishing up plastics,
Brasso ans silvo bring up chrome lovely,
If youve got an older bike or a less powerful one, youll find they'll be rated for SF oil. Asda cheapo 20/50, Motaman or similar is 20/50. Change your oil twice as often and change the filter at the correct mileage and youll save LOADs of money over supposed proper bike oils. My GT550 was just fine after 75000 miles of this! This will not make you clutch slip or other stuff in the horror stories you only need to worry about that in SJ,SL rated oils.
Check out www.gtttyres.co.uk , yes i know they're remoulds but they work well enough, i ran them on my FZR and my current GSXR 1100 and they've weathered well enough. CHEAP!
Get some plastic tubing, and a small washing up bottle that has a flip lid-not the sports drink style bottle top. This makes the best bleeding system in the world! I'll make a post on this. |
| Back to top |
| Bendy |
 Bendy Mrs Sensible
| Back to top |
| mr.z |
 mr.z World Chat Champion
 Posted: 11:04 - 08 Feb 2005 Post subject: Re: Biking on a budget - Any tips?? |
| bish777 wrote: | This will not make you clutch slip or other stuff in the horror stories you only need to worry about that in SJ,SL rated oils. | allthough its bike dependant, any friction inhibitors you find in car oils WILL make the clutch slip, also loose compression in some cases.. same goes for oil additives, read very carefully what your putting into your engine..[/quote]
| Quote: |
Check out www.gtttyres.co.uk , yes i know they're remoulds but they work well enough, i ran them on my FZR and my current GSXR 1100 and they've weathered well enough. CHEAP! |
Personally i'd never buy cheepo tyres, remoulds are never as good as the originals, and when they are the only thing keeping you on the road i think its pretty damn important that they are up to the job... maybe if your courriering nice and cheep, wouldn't trust them myself though...
Used oil is excelent for lubeing your chain, take the chain off, clean it as normal, get a try big enough for all the engine oil, put the chain it, drain the still hot oil into it.. fish your chain out.
Milk bottles cut up carefully make excelent hand guards.
If your resivoir tank brakes just use a 1litre oil bottle cable tied on.
newspaper/bubble wrap will keep you warm in a real emergency.
Para boots (officers boots are a little more but allot more comfy) make very good bikeing boots, you can even get zips to go on after.
Plastic gloves you get at petrol stations over your gloves will keep you hands a bit dryer.
Army surplus kit bags (£13 mine was) will ratchet tie to a pillion seat or rack, i took a tent, sleeping bag, roll mat, cooking stuff and a chair, only one bag. (not warter proof, but black bin liner inside or outside fixes that)
Cable ties are worth haveing with you at all times, they will hold your sidepanels on for an indefinate time... apparently  ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| Back to top |
| bish777 |
 Posted: 11:40 - 08 Feb 2005 Post subject: Re: Biking on a budget - Any tips?? |
| zero wrote: | allthough its bike dependant, any friction inhibitors you find in car oils WILL make the clutch slip, also loose compression in some cases.
ALL SF/SG oil will work in bikes. The friction inhibitors in car oils that cause problems in bikes were intorduces in oil with newer specifications-SL on. This is information i got back from the company labs-i work for texaco. I used it in my GT550, which i ran mostly in urban areas, which would have revealed any weaknesses in the clutch.
As for the remoulds, i've run a few pairs and they worked fine. I only recommend the Tomahawks because i've used them. That was on a FZR 1000 and my current GSXR 1100, so the remoulds were given quite a hard time, on the rear hoop at least. I find it hard to argue at 94 quid for a pair of tyres, delivered. |
| Back to top |
| Kickstart |
 Kickstart The Oracle
| Back to top |
The last post was made 21 years, 297 days ago. Instead of replying here, would creating a new thread be more useful? |
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.09 Sec - Server Load: 0.29 - MySQL Queries: 15 - Page Size: 49.6 Kb
