I have electrical
davidlevang
PostPosted: 04:22 - 15 Mar 2005    Post subject: I have electrical Reply with quote
My bike (the x9) has no electrical power. I have tried the battery and the signal I get from the charger says its full... Then I tried the fuse and it seems fine I put it in another bike to test it and it worked. What else should I try?
Claud 14.7 to 1
PostPosted: 04:30 - 15 Mar 2005    Post subject: Reply with quote
What works/doesn't work? Does the engine turnover/electrics work? etc?
Guest
PostPosted: 08:59 - 15 Mar 2005    Post subject: Reply with quote
Dunno the zx9 specifically, but on big Suzukis there's a main fuse in the connector block on top of the starter solenoid. The juice comes from the battery, through this fuse, up toi the ignition switch then back to the main fuse box to liven everything else up.
If you've got volts after the main fuse but not back to the fuse box then I'd check the connections between the two, or it could be the ignition switch itself.
White Noise
Mr Dudwee
PostPosted: 13:42 - 15 Mar 2005    Post subject: Reply with quote
I think that it might well be a case of getting a cheap multimeter from somewhere and testing from the battery outwards and seeing where the volts drop off, a circuit diagram would be very handy i.e a haynes manual, good luck in tracking the fault down.
WN
The last post was made 21 years, 205 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.6 - MySQL Queries: 14 - Page Size: 38.3 Kb
