Loss of power for some reason, engine tone changed
simon1221
PostPosted: 20:07 - 09 Mar 2005    Post subject: Loss of power for some reason, engine tone changed [HELP!] Reply with quote
The engine sound is different (smoother, with a less harsh fire to it), but less powerful.
It sounds like fuel starvation, but:
Fuel level is correct in carb as that is what i have just checked this afternoon.
I have an inline fuel filter , but that has an arrow on it that is currently pointing in the direction of the carb, so I think that is the right direction.
Breather pipes in carb are clear as petrol spurted out of them when i turned the carburettor upside down (oops!). Not sure about the one on the tank.
Anything else it could be?
DNA50 (sorry) ->> TZR125l >> GPZ500S
nick.h
PostPosted: 20:09 - 09 Mar 2005    Post subject: Reply with quote
While applying the throttle you get no response for a few seconds from the engine at high revs? Thats what my bikes been doing, but I just put it down to the cold weather.
[Italjet MM5A] ll [Rieju RS1 Evolution] ll [Suzuki GS500e] ll [Suzuki GSX600F] ll [Honda CG125] ll [Pug Elyseo 125] ll [Yamaha YZF750R] ll [Yamaha Thunderace] ll [Yamaha R6] ll [Triumph 955i] ll [Hayabusa RZK3] ll [Suzuki RGV250] ll
palmer
Fiddled Kiddy
PostPosted: 20:13 - 09 Mar 2005    Post subject: Reply with quote
have you tried thrashing it? Very Happy usually fixes my 2t problems Thumbs Up
simon1221
PostPosted: 20:23 - 09 Mar 2005    Post subject: Reply with quote
Dont know, never tried.
But its the time after that is annoying.
I am not going to rag it as if it is fuel starvation then the higher revs you go, the less fuel you will have, making the mixture leaner as the revs increase, so by the time i would have got to the redline it would have blown up!
ZRX61
Victor Meldrew
PostPosted: 02:58 - 10 Mar 2005    Post subject: Reply with quote
The engine looses power when ya close the throttle after revving the nads off it? who'da thunk it? Rolling Eyes
mchaggis
PostPosted: 04:22 - 10 Mar 2005    Post subject: Reply with quote
Sticky throttle cable taking its time to return?
I must not be a troll...
Mmmm, Guinness
simon1221
PostPosted: 13:30 - 10 Mar 2005    Post subject: Reply with quote
1) It isnt the throttle itself, it just doesnt fire correctly.
It does it all the time now, not only in high revs.
Instead of a roar (sort of), its more like a pffff sound.
Maybe the oil pump is set to high?
2) And it has also started to (almost) stall when going through junctions, at say 2000rpm, the bike 'runs out of fuel, misfires, then carries on.
mchaggis
PostPosted: 16:27 - 10 Mar 2005    Post subject: Reply with quote
Dodgy spark plug/ HT lead? Clarted up carburettor? Coked up exhaust? Leaky carb rubber?
Mmmm, Guinness
simon1221
PostPosted: 17:55 - 10 Mar 2005    Post subject: Reply with quote
Pretty new spark plug, iridium one.
Last thing really, piston rings?
cagiva gezzer
PostPosted: 18:22 - 10 Mar 2005    Post subject: Reply with quote
If its sounding soft its a lack of compression. Crank seals, reed valves, rings, head gasket.
simon1221
PostPosted: 15:31 - 11 Mar 2005    Post subject: Reply with quote
There the most difficult to check.
Not head gasket, otherwise there would be water everywhere.
Havent touched the reed valves.
Either rings or crank seals.
simon1221
PostPosted: 16:52 - 11 Mar 2005    Post subject: Reply with quote
How do i check compression?
Hex
Party Boy
PostPosted: 17:05 - 11 Mar 2005    Post subject: Reply with quote
Nah, if its fuel starvation it wont "lean" the mixture out, you just wont accelerate as the fuel wont be there, as such it wouldn't run lean and blow up.
As for what the problem is, you haven't really described anything to me that immediatly points to anything.
I would try a new spark plug just to check - iridium or not - not would be cheeper and do just a good job. But really need to know more about what the bike does when you twist the throttle not how its sounding here.
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
mchaggis
PostPosted: 17:27 - 11 Mar 2005    Post subject: Reply with quote
You need a compression test to screw into the sparkplug hole to test for certain, but a general guide is whether you can hold your thumb over the hole. If your thumb is forced off with the pressure, then it (the compression) stands a chance of being okay.
It's entirely possible that you've got dodgy piston rings - the sign of an imminent rebuild?
Mmmm, Guinness
simon1221
PostPosted: 19:39 - 11 Mar 2005    Post subject: Reply with quote
I will try and be as useful as possible:
Arrow Only starts on about 4th or 5th kick
Arrow May sometimes stop while warming up (starts 1st kick afterwards though)
Arrow Tends to be unresponsive when doing junctions (in any gear) after decelerating from national speed limit
Arrow Tends to have a flat spot between 4 - 5000 revs, which only usually happens if the engine is flooded, but it isnt
Arrow Doesnt fire well and is pretty spluttery at low speeds, but the mixture is correct (or as much as it can be)
I will get a new plug tomorrow, I think.
Hex
Party Boy
PostPosted: 09:48 - 12 Mar 2005    Post subject: Reply with quote
Try a different temperature plug? Maybe the recent cold weather aint helping matters.
Flat spot around about there is normal.
Tarmacsurfer
PostPosted: 14:52 - 12 Mar 2005    Post subject: Reply with quote
What sort of mileage is the bike, and has it been rebuilt since new? I'm inclined to agree with the piston ring theory going on current info Neutral
I'm immortal. Well, so far.
simon1221
PostPosted: 20:37 - 12 Mar 2005    Post subject: Reply with quote
Its on 15000 miles.
I dont know if it has been rebuilt since new, i have only had a few months and the last guy was useless.
simon1221
PostPosted: 17:27 - 14 Mar 2005    Post subject: Reply with quote
It was alright today, I was fed up of feeling it was going to die so just ran up to the nearest town and back at 8-9000 revs.
Oh yes i also put redex in (havent had any for a while due to me being lazy) so im thinking its just another godamn fuel blockage.
DM
PostPosted: 18:21 - 14 Mar 2005    Post subject: Reply with quote
Just described my bike when it's working well (minus the power loss) Laughing.
BFG
PostPosted: 20:01 - 14 Mar 2005    Post subject: Reply with quote
This is a two-stroke 125, yes? They're meant to live at over 8000rpm. Sounds like you're oiling the plugs up by under-revving it.
The last post was made 21 years, 249 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 109.44 Kb
