Removing heated grips?
TiN
Pocket Tin
PostPosted: 14:53 - 27 Mar 2005    Post subject: Removing heated grips? Reply with quote
Just wondering, how would one go about removing a set of heated grips (Oxford, if that makes any difference), preferably without destroying them?
With standard rubber grips, they are flexible enough to pry open and squirt in some WD40...but with these heated grips, they're kinda solid.
Any suggestions welcome. Ta.
TiN
dotgems.net
BlueNinja
PostPosted: 17:01 - 27 Mar 2005    Post subject: Reply with quote
Heya.
Get yourself a can of hairspray. This removes the grips easy. Better the WD40, because it dries up and doesnt leave any oil for it to fall of again.
When you put them back on, use hairspray again, (spray bar nicley) put it on, and leave it. Hair spray will stick it back down very well again. Smile (dries and stays very sticky)
Good luck! Thumbs Up If you must, lift the edges with a screw driver, then spray the hair spray in. Then continously grip and twist the grip untill it loosens.
Big Kawasaki ZXR 400 project here:
https://www.theundertaking.com/index.php?showtopic=483
The last post was made 21 years, 182 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.37 - MySQL Queries: 14 - Page Size: 31.83 Kb
