(kmx 125) rattly sounding engine in the mid range
KevlarPants
PostPosted: 12:07 - 27 Mar 2005    Post subject: (kmx 125) rattly sounding engine in the mid range Reply with quote
I've only had by kmx 125 out a couple of times so far, but I've noticed that the engine sounds quite rattly/gurlge-y when the throttle is in the middle position. By that I mean not fully on or off, but in the mid range.
Now the bike has had a service less than a couple o hundred K ago, so I'm assuming that this is just the way 2strokes (or at least this 2stroke) sound.
Does that sound reasonable? Perhaps I'm just being paranoid. When I had it out on the dual carriageway yesterday in top gear at about sixty the engine sounded quite happy ...
ta
Finglonga
PostPosted: 14:58 - 27 Mar 2005    Post subject: Reply with quote
Er it was years ago when I had one, but I seem to remember the KIPS system made arattling sound when something had worn and needed replacement.
Mid throttle is where it started to open/close or whatever it did.
Andy Sez....
F.Y.Y.F.F.
stevo as b4
PostPosted: 00:46 - 28 Mar 2005    Post subject: Reply with quote
The KIPS system shouldnt make any noise really. It just operates the valves at around 6500ish rpm. Is the sound your bike is making a mechanical rattling noise would you say, or a popping/crackling sound? If its the latter it could be a bad seal at the exhaust pipe or silencer for example. My old kmx200 used to pop and crackle like a bowl of rice crispies if i went down a hill, with the throttle just slightly open. Its only because the bike is fourstroking on light load with small throttle openings though.
The last post was made 21 years, 185 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.75 - MySQL Queries: 14 - Page Size: 35.7 Kb
