| Visitor Q |
 Visitor Q $25 whore
 Posted: 16:10 - 29 Mar 2005 Post subject: Crashbung fitting. |
Right, i want to fit crash bungs too my CBR 600 steel frame, and im being quoted around 70-80 quid to have two holes drilled in the fairing, on top of the 50 quid for the bungs. Call me old fashioned but that kinda ruins the point of having them.
Can anyone tell me some tips on how to line up the holes in the fairing with the mount, how to drill it neatly and completely on target, and what tools are needed? ____________________ China traffic/travel bike vid - When I make a sweeping statement, please add the word 'statistically' in to the sentence before you bitch...
From September 2014 to January/February 2015 I will not be using any English, nor reading any. As such, I won't be on here. PM at will, but I won't be checking/posting unless in emergencies. Certainly not for the first couple of months. Please berate me savagely if I break that rule... |
| Ste |
 Ste Not Work Safe
 Posted: 16:23 - 29 Mar 2005 Post subject: |
Remove the fairings and undo the engine bolt. Pull the engine bolt out so its sticking out in the way of the fairing and put some tipex on the end of it, keeping it there put the fairing back in place and you've now got a tipex marking on the back of your fairing where the hole needs to be drilled.
Start by drilling a small pilot hole and once you're sure its in the correct place use a bigger drill bit, drill it neatly by being smooth and you can sand the edges down after you've finished to make it neater if you want.
What tools, some tippex, tools to remove fairing and engine bolt, small drill bit for drilling pilot hole and a 25mm for drilling the actual full size hole.
There are instructions on the R&G Racing website which will be pretty much the same for all mushrooms which mount like that.  |
| Visitor Q |
 Visitor Q $25 whore
 Posted: 17:00 - 29 Mar 2005 Post subject: |
| Ste wrote: | Remove the fairings and undo the engine bolt. Pull the engine bolt out so its sticking out in the way of the fairing and put some tipex on the end of it, keeping it there put the fairing back in place and you've now got a tipex marking on the back of your fairing where the hole needs to be drilled.
Cool. What about making sure the fairing is aligned correctly with the bolt when putting it back on to mark it? Surely if its angled slightly it will go pete tong?
I spose with two and a half cms to play with theres a lot of margin of error for the pilot hole.
Thanks for the advice anyway mate  ____________________ China traffic/travel bike vid - When I make a sweeping statement, please add the word 'statistically' in to the sentence before you bitch...
| Visitor Q |
 Visitor Q $25 whore
| Ste |
 Ste Not Work Safe
The last post was made 21 years, 192 days ago. Instead of replying here, would creating a new thread be more useful? |
