| simonthepiema... |
 simonthepiema... Renault 5 Driver
| mchaggis |
 mchaggis World Chat Champion
 Posted: 14:57 - 12 Apr 2005 Post subject: |
White spirit is fine for cleaning the gauze filter. As for sump plugs, I've got by just tightening mine by feel until it doesn't feel like it wants to go any more, then putting another quarter turn on it.
Running for a bit more than 30 seconds might be an idea to get the oil properly hot and runny, or at least running it long enough to warm it up properly. Just be careful not to burn yourself.
Smearing oil around the rubber seal on the filter nut might make it easier to remove next time, but assuming it has the spring holding the gauze filter in, it's always a pain. ____________________ I must not be a troll...
Mmmm, Guinness
Discovering the delights of Hammerite and a 3/4" brush.  |
| Scotsman37 |
 Scotsman37 World Chat Champion
| mr.z |
 mr.z World Chat Champion
 Posted: 17:55 - 12 Apr 2005 Post subject: |
Its not a bad job to do, there might not be a sump plug on there (if its the brazilian model) the oil is emptyed from the filter houseing...
If you do clean the filter (if it looks bad then might be worth doing) make very very sure what you cleaned it with is gone by the time you put it back..
The thing with torque is its difficult to gage unless your quite experianced, it depends on who is doing it, what spanner your useing, where your holding the handle! IMO if you plan on doing anything like this reguarly then invest in one, because allthough you might get away with it 99% of the time on day you might not, and its never good.. overtightening the sump plug for example can cause hairline fractures in the caseing, giveing you a leak that will never be fixable (untill you change the case!) not to mention other horrors...
I was just retightening an inspection cover and had to guess it, the other bolt i could get to with it and it needed almost no pressure
Best to take the bike for a short run or let it idle for 5 minutes to warm up.. (dont forget the oil will be a little bit on the warm side when it comes out!) ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| simonthepiema... |
| mr.z |
 Posted: 21:49 - 12 Apr 2005 Post subject: |
Your only likely to get an official honda one (phone your local honda dealer), to be honest its not really designed to be changed just cleaned unless it breaks obviously, if you really wanted it cleaning to new condition then you could get your local mechanic to out it in their parts cleaner, even better a sonic bath... would probably cost the same but will save the hassle...
It took me a while to work out there shouldn't be a sump plug, when you take the (sprung) filter cap off be carefull not to loose it in the oil, bit of a pain fishing it out!
I asked because i have the haynes for the older model but not that one so can't help much there... its worth getting one though, if you buy one new clymer do a better one..
good luck  ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
The last post was made 21 years, 181 days ago. Instead of replying here, would creating a new thread be more useful? |
