aprilia piston change rotax 123
john0207
PostPosted: 20:04 - 23 Apr 2005    Post subject: aprilia piston change rotax 123 Reply with quote
my bike overheated and i think the head gasket has gone or the piston or the rings have had it( "no compression").
i was going to get an engine from ebay but have decided to just change the piston and gaskets.
it a 1998 rs 125 extrema so i think its a rotax 123 engine i think?
does anybody know how difficult this is or should i let a garage do the work.
i not in any hurry really and would like to give it a go myself if i can
cheers
john
ps thanks to "kickstart" for his help with my other questions about the problem.
PostPosted: 20:59 - 23 Apr 2005    Post subject: Reply with quote
At that age it may be a 122 or a 123 engine. Pistons are the same I think.
However it is has seriously overheated then the chances are that it has nipped up, wrecking the rings and the barrel as well as the piston.
A piston can be had for about £80 through Peter Knight (0176 141 4106) (he is a Rotax specialist) or for about 50% more through Aprilia. You can get non Aprilia / Rotax pistons which are of a decent quality but make sure they are from a supplier you trust.
You can get a scored barrel repaired and replated from someone like PJ Engineering in Wolverhampton.
Changing the top end of the engine is not difficult. Just take your time.
john0207
PostPosted: 09:01 - 24 Apr 2005    Post subject: Reply with quote
will i need a manual to change the piston , or will it be obvios what to do when ive opened it up.
cheers
john
Most motorcycle problems are caused by the nut that connects the handlebars to the saddle
PostPosted: 11:58 - 24 Apr 2005    Post subject: Reply with quote
If you know roughly what you are doing then you can get away without a manual, but if you have never changed a piston before then one would be a very good idea. Peter Knight can supply a copy of the engine workshop manual.
keith
The last post was made 21 years, 166 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.72 - MySQL Queries: 14 - Page Size: 42.76 Kb
