Leathers
ApriliaRs125
PostPosted: 16:54 - 18 Apr 2005    Post subject: Leathers Reply with quote
hello peeps summers just round the corner and i want to get some leathers , any one no any online shops?
P.s. dont want to spend toooo much money
scott
*aprilia rs125 2005 UKRS https://www.theukrsclub.com
*peugeot speedfight 100 1999 Aprilia Forum https://www.apriliaforum.com
Ric
PostPosted: 17:11 - 18 Apr 2005    Post subject: Reply with quote
RST are pretty good from what ive herd
£199 for a full 2 piece sounds like a bargin, id say boots are a must too
cc123
Geez a joab?
PostPosted: 17:26 - 18 Apr 2005    Post subject: Reply with quote
Yes, fully leathers and a pair of Nike Air Max just ain't gonna go! Laughing
Old bikes >>> https://www.bikepics.com/members/cc123/
Mr.Everready
PostPosted: 17:28 - 18 Apr 2005    Post subject: Reply with quote
theres 100's. Do a Google search for motorcycle leathers.
Mr.Everready
PostPosted: 17:29 - 18 Apr 2005    Post subject: Reply with quote
Meant to add, its best to try them on first if you can.
Turbo Busa
PostPosted: 17:31 - 18 Apr 2005    Post subject: Reply with quote
With bike leathers you really get what you pay for. A lot of the cheaper suits are made from thin or sub-standard leather and very often the stitching will come apart in an accident. If you are on a tight budget then what you may want to consider is buying a second hand set from eBay. Before you throw up, think about this.....a lot of leathers are worn a handful of times and then stuck in the wardrobe. it's quite normal to see a £1,000 set of Dainese or Alpinestar go for a couple of hundred quid and they are often AS NEW.
The thing to do is forget the budget, go to a good store and try a few suits on, the sizing and fit varies greately. Find your perfect size and the make/colour you'd really like (get a short-list of 2 or 3 to speed things up), then start scouring www.ebay.co.uk
I guarantee that you'll find what you want in a fairly short time and you'll end up for something far better than you'd ever thought you could afford.
Just a thought Wink
T.C
PostPosted: 21:18 - 18 Apr 2005    Post subject: Reply with quote
Price does not come into it. 95% of all leathers all come from the same factory in Sialkot in Pakistan, which includes the likes of Dainese, RST and the like. In fact last time I was at the factory in Pakistan I had the choice of Dainese, Lookwell, Fieldsheer, Frank Thomas and a whole host of others for about £10.
Even if you go to Brick Lane in London you will buy a quality unbranded suit from the same factories for about £60, and it will afford the same protection as the dearer branded names.
Under the EC personal protective equipment directive, a series of European standards are being developed for motorcyclist protective clothing that will be designed to.
1. Prevent or reduce laceration and abrasion injuries.
2. Prevent or reduce impact injuries such as fractures, broken bones and joint damage.
These standards marked with a CE mark are essentially to help riders distinguish between clothing that offers a minimal level of protection, and garments that may look similar but offers very little if any protection at all.
Unfortunately for many riders, the buying of new leathers is often no more than a fashion statement as opposed to a desire to maximise their protection, but, contrary to popular believe you can be fashionable and protected.
As with helmets, there are accidents and injuries from which even the best or most expensive clothing will not protect the rider. It is therefore important not only to try and reduce the severity of the injury, but also ensures that the garment is comfortable, does not impede your movement and will reduce the affects of fatigue thereby aiding concentration.
Leather is still regarded as the best form of protection against injury when riding a motorcycle. They are made from a natural material, which is breathable, abrasion resistant and supple. Like a crash helmet, they cannot offer total protection from injury, but they can reduce the severity and long term affects if they fit correctly.
Leather garments can be made from 4 different animals, Cow, which is the most commonly used, Goatskin, Buffalo or kangaroo skin.
Cowhide is the preferred choice of most manufacturers. It is heavy duty (compared with the others). It is hard wearing, and in the main the manufacturers use 1.4mm thick hides, which means that in the summer weather with the thickness and all the padding they can get hot inside.
Buffalo hide is often used on cheaper garments and this can be felt in the overall quality when compared to other leather products. Buffalo is tough, will last well but it tends to be a very stiff leather and can take some time to bed in and soften up.
Goatskin although worth considering as an alternative for summer use is very difficult to find in the UK. It is considerably lighter and more flexible than Cowhide, and many consider the goatskin to be stronger than cowhide due to the fibres being more closely knit together than cow skin. The downside is that goatskin stretches a lot quicker than cow so it may require specialist tailoring on an annual basis.
Kangaroo is probably the least known of the hides used although they are being used more regularly in very hot climates. The hides are supple, light and quite tough, but it has been found that they can react with sweat particularly when worn by riders who perspire freely. If this were the case then you would probably be well advised to look elsewhere as you may find your suit literally coming apart at the seams.
For those considering purchasing leathers for the first time, the question often asked is whether to purchase a suit/jacket combination, two piece suit or a 1 piece racing suit. The choice comes down to individual preference, but here are a few points that you may find useful to consider.
1. A jacket and trouser combination is probably the most popular choice for the majority of riders, and, they can be worn singularly or in combination. However, many jackets (not all) have a Thinsulate lining for warmth retention together with a quilted lining. Many riders to complain that they overheat in warm weather which can ultimately affect concentration. However, this combination is ideal if you are an awkward size or on a limited budget.
2. A two piece zip together suit can be a good choice for a number of reasons.
- They can normally only be worn as a complete garment thereby maintaining your crash protection.
- They come in a number of colour choices therefore conspicuity can be enhanced.
- They are normally lighter than jacket/trouser combinations which for some means they will be more comfortable for summer or warm weather use.
- When stopping for a break, the jacket can be unzipped from the trousers thereby enhancing comfort when away from the bike.
- They maintain their shape and size better.
- They often have features such as perforated leather to allow air to pass through in warm weather, stretch fabric panels behind the knees, waist and inner thighs which again can enhance warm weather comfort.
On the downside, riders may also wish to consider that:
- They can normally only be worn as a complete suit.
- They can take a while to break in and mould to your shape.
- They are not particularly warm in the colder weather.
- There are not as many pockets as in a jacket/trouser combination, which for some may be a good thing.
- The colours tend to be more flamboyant than jacket/trouser combinations.
One Piece suits are the other alternative often favoured by those who ride Supersports or participate in track days. Whilst offering a fair degree of protection, for road use they have often been deemed impractical as you cannot separate them when away from the motorcycle, but more importantly in serious accident situations, the emergency services have occasionally experienced difficulty in rendering an effective diagnosis or treatment simply because they cannot cut through the leather to tend to the riders injuries, or they cannot risk removing the garment without fear of causing further injury. This of course comes down to a matter of preference.
Leather is abrasion resistant, and its main function is allow you to slide, thereby reducing friction. From new, leathers should fit as tightly as possible to allow for stretching and moulding to the wearer’s shape. If the leather is a poor fit then there is the possibility that as the rider slides down the road, the friction caused by the road surface will cause the leather to snag. This could cause a flailing limb to snag and whilst the torso is still travelling at speed, the flailing limb will slow down too quickly and can result in severe injury. On the plus side, good fitting leather can slow down any potential blood loss, particularly internal blood loss, or it can at least stem the flow until medical help arrives on the scene.
If you are unfortunate enough to be involved in an accident as a result of which you are injured (and we all hope that it doesn’t happen), at least you can be comforted that the severity will be less than if you were wearing non protective clothing, and the sympathy you receive from the emergency services and Hospital will be far more favourable than your compatriot wearing his jeans and trainers
So in conclusion, price is not the issue, it ias how it is constructed, and in all honesty a 1.4mm piece of cardboard will be less protective than say .5mm of goatskin or kangaroo, and the heavier the leather the less comfortable you will find it in the height of summer.
So, don't go by price, buy according to quality and most importantly make sure they fit, and rest assured there are some very good budget leathers out there which knock some of the more famous branded names for six!
It is better to arrive 30 seconds late in this world, than 30 years early in the next
Akiraprise
PostPosted: 21:29 - 18 Apr 2005    Post subject: Reply with quote
wow TC that post was great, I learnt alot thanks Smile
loply
PostPosted: 23:03 - 18 Apr 2005    Post subject: Reply with quote
I can attest that cheap bike leathers (particularly those with unofficial logos or brands on them) will fall apart in a crash. My "Triumph" jacket off ebay for £60 new did its job fine, however it fell to pieces in the process- Split completely in half in several locations. 20mph more and it would have put my skin on the ground.
I dont know but I would bet the same wouldnt have happened with leathers from a "proper" company, as they would have had stitching inside or double layers around the seams etc.
Yamaha SZR660 Caution to the wind, the throttle pinned!
T.C
PostPosted: 23:15 - 18 Apr 2005    Post subject: Reply with quote
I will take that bet!
I have a £1400 suit in my possession that fell apart at a little over 40 MPH. It is branded, tailor made and from a reputable maker.
Read what I said, even the branded suits come out of the far east, the branded means diddly squat unless you pay tailor made money and stand over them whilst they make it! Rolling Eyes
In your case the leather did exactly what it was designed to do, protect your skin ONCE! They are not designed to take multiple crashes although many do, but that is a bonus.
Mr.Everready
PostPosted: 00:08 - 19 Apr 2005    Post subject: Reply with quote
Was your jacket a "fashion" jacket loply ?
Mr C
PostPosted: 00:45 - 19 Apr 2005    Post subject: Reply with quote
one word
"CROWTREE"
made in the UK from British cows Laughing
187.3bhp = 201mph
Turbo Busa
PostPosted: 00:47 - 19 Apr 2005    Post subject: Reply with quote
Dave, you KNOW they are made in Sialkot from Llama scrotums Rolling Eyes
Mr C
PostPosted: 00:48 - 19 Apr 2005    Post subject: Reply with quote
hehehe
yes
I went there to see them being made
the Llamas were still limping
187.3bhp = 201mph
Mr C
PostPosted: 00:50 - 19 Apr 2005    Post subject: Reply with quote
Ken12r went in to Crowtree to pick his new suit up last week and they were dicussing mine which is in for repair
apparently the armour and lining was soaked in blood
I had no idea Shocked
187.3bhp = 201mph
Mr C
PostPosted: 00:52 - 19 Apr 2005    Post subject: Reply with quote
oh and by the way, that was caused by a razor sharp piece of perspex travelling at 180mph
well I was
not the perspex
if you see what I mean
187.3bhp = 201mph
White Noise
Mr Dudwee
PostPosted: 00:53 - 19 Apr 2005    Post subject: Reply with quote
was that from the sign/ZX12 incident?
WN
Buy my wife: 96' Yam XJ600s (Diversion)
Wing Commander White Noise - SE Clique
Riding Tip #86: See God, then back off a bit: Problem is i haven't seen god yet, just a close up of tarmac on revett straight
Mr C
WN
mmm hmmm Embarassed
187.3bhp = 201mph
White Noise
Mr Dudwee
PostPosted: 00:56 - 19 Apr 2005    Post subject: Reply with quote
thought that you got away scott free (apart from mangling your bike) at least you will have the scare to remember to watch out for big fcuk off boards! (no offence), can't believe how lucky you where
WN
Mr C
PostPosted: 00:58 - 19 Apr 2005    Post subject: Reply with quote
me either
watch Streetfighters magazine for a possible feature Wink
I think I got a mention this month
187.3bhp = 201mph
The last post was made 21 years, 165 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 112.49 Kb
