Why is brake fluid so evil
White Noise
Mr Dudwee
PostPosted: 22:01 - 18 Apr 2005    Post subject: Why is brake fluid so evil Reply with quote
Well after having my first encounter with brake fluid this weekend, i am wondering why it is so evil! i know that the demands that are put on it are great but what is in it and why that makes it eat paint!
WN
Buy my wife: 96' Yam XJ600s (Diversion)
Wing Commander White Noise - SE Clique
Riding Tip #86: See God, then back off a bit: Problem is i haven't seen god yet, just a close up of tarmac on revett straight
Bezzer
PostPosted: 22:49 - 18 Apr 2005    Post subject: Reply with quote
It's just the formula they use, trading off best for use against the various side effects. The Glycol Ethers present are the most likely cause of the paint eating, it's highly corrosive.
You can get a non corrosive fluid - silicone based DOT5 that's got higher boiling temp but really should just be used for racing, track daying etc as it goes "off" quickly and has to be changed regularly. DOT 5.1 is an attempt to gain the attributes of 5 but with the plusses of the longer life 3 and 4 fluids....but I think that has the Glycol Ethers as well in the formula so it's back to square one. Rolling Eyes
mchaggis
PostPosted: 22:50 - 18 Apr 2005    Post subject: Reply with quote
Tri and tetraethylene glycol mono alkyl ethers, their borate esters and corrosion inhibitors.
The ethers are organic solvents, which boil at 300+ degrees C. The use of corrosion inhibitors should be fairly obvious. The borate esters are for anti-oxidising, anti-foaming, viscosity modifying etc..
Anyway, pretty nasty chemicals; the solvents are needed to dissolve the other stuff in and provide the main bulk I should think.
I must not be a troll...
Mmmm, Guinness
mr.z
PostPosted: 01:09 - 19 Apr 2005    Post subject: Reply with quote
Just a sidenote: droping a phone into a shallow bucket of it will not do the phone any good.
Wave2k
G's Stalker
PostPosted: 01:30 - 19 Apr 2005    Post subject: Reply with quote
fuck DOT4 just use water Thumbs Up
Ducati 1299 Panigale
2009 Corvette C6 z51
Will87
PostPosted: 11:05 - 19 Apr 2005    Post subject: Reply with quote
Water corrodes and if i remember an in-depth discussion about bicycle disk breaks it, does compress although slightly.
cunni
PostPosted: 12:51 - 19 Apr 2005    Post subject: Reply with quote
I've had a few encounters with this Dot4;
I had it on my hands for hours, no effects.
I've had it on my clocks for 2 months (after the brake reservoir got smashed), they are fine.
I've had it on painted wheels for approx. one day and they are fine.
All of the above had a clean after the stated time. I think it is only really danagerous to anything if left there indefinatly. It doesn't appear to be that bad at all.
As for whether I should have left it there in the first place, I was having a bad day trying to bleed a new brake system and getting nowhere! Crying or Very sad Laughing
TL1000R Parts For Sale!
PostPosted: 13:31 - 19 Apr 2005    Post subject: Reply with quote
DOT5 does not go off pretty much ever. It does not absorb water (which is an advantage, but also a disadvantage as it means it is difficult to get rid of any water that does get into the system).
Its boiling point is not great, and it is not very good for racing as it tends to give a very spongy feel.
Bezzer
PostPosted: 20:19 - 19 Apr 2005    Post subject: Reply with quote
You're getting mixed up dude, DOT 5 is used in racing applications BECAUSE it has a higher boiling point (around 500F ) compared to DOT 3 and 4 (around 400-450F)
You get the spongy feeling because of the water in the system as it stays seperate which is why I stated it goes "off" quickly and is changed frequently e.g. every race every trackday.
J.K.R
PostPosted: 21:02 - 19 Apr 2005    Post subject: Reply with quote
Comes in real handy for decorating very pesky neighbours cars Shifty Twisted Evil
PostPosted: 21:04 - 19 Apr 2005    Post subject: Reply with quote
Just checked the boiling points and you are right, both wet and dry (although 5.1 is better than all of them).
However DOT 5 does not absorb water at all, There is no reason for it to get contaminated and thus need regular changes unlike DOT 3, 4 or 5.1. This is one reason why it is used by some people in classic cars as they car just fill it and forget it for the next decade.
Getting water into a system filled with DOT 5 is a bad idea as it is difficult to remove.
The spongy feel is because silicone based fluids are slightly compressable.
Motkram
PostPosted: 21:07 - 19 Apr 2005    Post subject: Reply with quote
Water does not compress one little bit, and the best thing to do if you spill brake fluid on your beloved's paint work is to rinse with cold water. The fluid is diluted with it and becomes more or less harmless. (as far as paint is concerned, anyway)
Part-time GSXR1000 pilot>Micron Serpert system+K&N, PC111, Sigma slipper clutch, Brembo m/c+Galfer discs, Gilles rearsets, Translogic Quickshifter.
GP125>GSF400>VFR400NC30>YZF600R>YZFR1(1998)+KLR250>YZFR1(2003)>CBR900RRY>YZFR1(2002)>GSXR1000K1+RGV250
PostPosted: 21:19 - 19 Apr 2005    Post subject: Reply with quote
Water may not, but it does boil easily and the results of that compress.
dibbster
PostPosted: 23:21 - 19 Apr 2005    Post subject: Reply with quote
Liquid water will compress but requires high pressures, however it does not compress appreciably.
Suzuki RF 600 - The two wheeled Testarossa (Deceased)
Suzuki GSXR - Now stops on a sixpence; SBK3's Thumbs Up
www.bikepics.com/members/dibbster
The last post was made 20 years, 253 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 86.03 Kb
