Changing Gear
dainesefreak
PostPosted: 14:31 - 20 Apr 2005    Post subject: Changing Gear Reply with quote
To clutch or not to clutch?
I found this article over the the 1000rr site thought someone might find it interesting. (or not Shocked )
https://www.vf750fd.com/blurbs/shifting.html
Mr.Everready
PostPosted: 14:52 - 20 Apr 2005    Post subject: Reply with quote
Theres alot of reading there Shocked
Whats the gist of it ?
Zoffo
PostPosted: 14:56 - 20 Apr 2005    Post subject: Reply with quote
Find cluchless changes smoother and I tend to hit false neutrals between 1st and 2nd if I use the clutch. This can be a bitch if you've just cained it if first and miss second while doing 80 mph. You have to slow all the way back down til the bike accepts the gear or risk stripping cogs
https://hyperbikes.forumsplace.com/
Mr.Everready
PostPosted: 14:58 - 20 Apr 2005    Post subject: Reply with quote
I've never tried it, always a bit scared that it will do something Very Happy
killa
Won't Shut Up
PostPosted: 15:06 - 20 Apr 2005    Post subject: Reply with quote
Does Rossi do it?
Zoffo
PostPosted: 15:09 - 20 Apr 2005    Post subject: Reply with quote
killa wrote:
Does Rossi do it?
I'll ask him next time he manages to catch up Thumbs Up
Claud 14.7 to 1
PostPosted: 15:12 - 20 Apr 2005    Post subject: Reply with quote
killa wrote:
Does Rossi do it?
Laughing .
Yes he does.
I do clutchless in moderation, and only when "going for it". Used not to, but it's faster and I suppose I prefer having 2 hands holding on to the bars properly when reving full whack.
Loz VFR
PostPosted: 15:15 - 20 Apr 2005    Post subject: Reply with quote
does rossi do it??? Laughing
he accelerates whilst braking into corners so that he can get the power down earlier and keep the revs higher. so Id imagine that he does clutchless.
EuropeanNC30R...
Gay Hairdresser
PostPosted: 15:26 - 20 Apr 2005    Post subject: Reply with quote
I'd expect GP racers to use quickshifters tbh.
Claud 14.7 to 1
PostPosted: 15:27 - 20 Apr 2005    Post subject: Reply with quote
You mean blipping the throttle to keep the RPM high for optimum drive out of the corner? Acceleration and braking would kinda defeat the object. Smile
Correct me if I'm wrong Laughing . Any time you head out for a ride-out give us a shout. I have time to pop down to Southampton. Wink
*EDIT*
Yes they do, but they still use clutchless, just they can use W.O.T. when doing so. Which is the point of quickshifters. Wink
Barry_M2
PostPosted: 15:30 - 20 Apr 2005    Post subject: Reply with quote
You dont need to roll off the throttle on a GP bike (or any race bike for that matter!), soon as you go to engage the next gear up, it cuts the ignition for a split second to unload the g/box and allow you to select the next cog. Lets the rider keep the throttle open so the air flow into the engine remains uninterupted. Save's a few 10th of a second a lap apparently.
Loz - How can you accelerate while breaking? Very Happy Confused
cc123
Geez a joab?
PostPosted: 15:35 - 20 Apr 2005    Post subject: Reply with quote
Think he means blipping the throttle so the rev's match the engine speed when slowing down, stops the back wheel from locking or skipping.....
Not done that in ages actually Confused
Old bikes >>> https://www.bikepics.com/members/cc123/
Mr.Everready
According to reports this is what Rossi does. It made the bike news a few weeks back.
EuropeanNC30R...
Gay Hairdresser
PostPosted: 15:38 - 20 Apr 2005    Post subject: Reply with quote
Loz is right, it's been reported that Rossi goes through corners with both the brakes and throttle on - something to do with weight-distribution I guess?
Claud - The quickshifter does dipping the throttle work for them so 'clutchless shifting' is a bit irrelevant for Rossi Razz
Though I've noticed he still uses the clutch coming down the gears, probably to control rear-wheel chatter.
instigator
PostPosted: 15:39 - 20 Apr 2005    Post subject: Reply with quote
I don't change down a gear any other way.... Embarassed
Zoffo
PostPosted: 15:40 - 20 Apr 2005    Post subject: Reply with quote
True. It's like left foot braking in a racing car. The F1 cars only have a brake and accelerator pedal but mort use both feet to be able to apply the brake and accelerator at the same time. This allows them to build up heat in the disc for when it's needed without losing speed to early.
cc123
Geez a joab?
PostPosted: 15:41 - 20 Apr 2005    Post subject: Reply with quote
I thought locking the rear wheel was a beginners thing too!!? Laughing
Think it's all about learning about your bike too, I know what my brakes are capable of now and can judge when to change down. It's an art Wink
Claud 14.7 to 1
PostPosted: 15:47 - 20 Apr 2005    Post subject: Reply with quote
Yeah I was thinking about this. Maybe the concept/practice just goes too far over my head. Razz
Still though clutchless shifting though, isn't it? I mean the only thing they have is the electronic device that cuts the ignition, whereas we have to shut off the throttle "manually". I hope I understood you right. Smile
Barry_M2
PostPosted: 16:00 - 20 Apr 2005    Post subject: Reply with quote
[/quote]
Still though clutchless shifting though, isn't it? I mean the only thing they have is the electronic device that cuts the ignition, whereas we have to shut off the throttle "manually". I hope I understood you right. Smile[/quote]
You got it!
I was thinking of doing something simelar on the cheap years back, by putting a switch near the gear lever, and hooking it upto the side stand switch to cut the engine when you went to change gear! Me and my daft ideas!!!!! Very Happy Cool
EuropeanNC30R...
Gay Hairdresser
PostPosted: 16:02 - 20 Apr 2005    Post subject: Reply with quote
Laughing At last something useful for the sidestand switch to do.
RiderOfTheSto...
PostPosted: 17:26 - 20 Apr 2005    Post subject: Reply with quote
You use the brake and throttle at the same time a lot when riding off road. On certain tracks you might find that you need to do it all the way around. It keeps the bike in the burms where you want it.
It hurts doesn't it? Your hopes dashed, your dreams down the toilet. And your fate is sitting right besides you.
Nolongerhere
PostPosted: 17:36 - 20 Apr 2005    Post subject: Reply with quote
I do clutchless some times depends normally if I am feeling lazy. Down the gears I always use the engine more than brakes blipping the throttle and letting the clutch out after each gear changed!!!
loply
PostPosted: 23:30 - 20 Apr 2005    Post subject: Reply with quote
When I do clutchless shifts under heavy acceleration the next gear always comes in with a bit of a jerk, any idea how to avoid this?
I tend to roll off the throttle quite far and quite aggresively then snap it back open again.
Yamaha SZR660 Caution to the wind, the throttle pinned!
Zoffo
PostPosted: 23:33 - 20 Apr 2005    Post subject: Reply with quote
That's why. It's only a very small movement you need to do
paulyzf600
PostPosted: 23:52 - 20 Apr 2005    Post subject: Reply with quote
The best thign about clutchless gear changes are you are in more control when on full chat!
what happens when you open it up in second and the revs are at 13,000 RPM (well on my bike...lol) you need to change gear and if it's with the clutch you tend to grab the clutch as fast as possible and and then let go. This can shock the bar position and be pretty scary when you grab the clucth and end up wobbling the bars cos you grabbed so quick.
It's also for smoother and quicker but like said above you are nither on throttle or off throttle it's kind of the milly second in between that it happens! top end revs are smoothest as it's so quick mind watch cos it can sometimes supprise you as no sooner are you going to change when you are already in the gear and it's time to change again........lol
Yamaha YZF600 Thundercat
The last post was made 21 years, 167 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 128.95 Kb
