| matphillipsuk |
 matphillipsuk Borekit Bruiser
| Git |
 Git Brolly Dolly
| AdamBoyle |
 AdamBoyle Nova Slayer
 Posted: 17:17 - 21 Apr 2005 Post subject: |
Theres 4 allen key bolts that bolt the rubber tube to the intake, undo those... Im not taking my bike apart to find out more details, its pretty simple though [Have you got the plastic tray out?] ____________________ Bike - Honda NSR125R1 (Sold)
Passed Theory: 20/12/2007
Passed Practical Test: 10/03/2008 |
| matphillipsuk |
| swampy |
 swampy World Chat Champion
 Posted: 18:53 - 21 Apr 2005 Post subject: |
What you need to do is remove the airbox, then look at the other end of the carb. You should see a rubber manifold that leads from the carb to the reed valve block. At the carb end of this rubber tube, you will see a jubilee type clip. Unscrew this to loosen it and pull the carb from the manifold. Then unbolt the the black plate on top of the carb with the throttle cable running through it and pull the throttle slide from the carb body. Then unscrew the screw near to where the choke cable enters the carb and pull the choke slide out. Reassembly is the opposite of disassembly (as the Haynes manuals say )
By the way, it sounds like you have pulled the intake manifold out of the bottom of the air box, this is also jubilee clipped to the carb and should be loosened before pulling the airbox off. ____________________ "I hate to advocate drugs, alcohol, violence or insanity to anyone, but they've always worked for me." Hunter S Thompson
"Faster, faster, faster, until the thrill of speed overcomes the fear of death..." Hunter S Thompson |
| alains |
 alains World Chat Champion
The last post was made 21 years, 185 days ago. Instead of replying here, would creating a new thread be more useful? |
