| shellshock |
 shellshock Spanner Monkey
 Posted: 17:00 - 25 Apr 2005 Post subject: Hill Starts ? |
Took the other half pillion again today, went from Newcastle to the good old Cat n Fiddle, and I thought my days of stalling on hills were far behind me ...... not so
I managed to stall numerous times on a very slight incline, and eventually JP had to swap and get the bike onto flat ground, Oh dear
Thinking about it afterwards, I was using the old DAS way of getting up a hill, no front brake, use the rear brake as a handbrake method, this does not work for me. After this I stopped thinking about it and used my normal way, which is front brake (rear covered in case I stuff up) and then quickly onto revs and away (if that makes sense), I don't use my handbrake in the car, preferring to keep the car at a standstill by means of clutch control and biting point, and think I have transferred this method into a bike way of doing it.
Anyway, I think this makes sense, does anyone else use my method ? Do you think its safe enough ? or do you think I should go out and practice the rear brake way until I get it right ? |
| Ian (GPX) |
 Ian (GPX) Brolly Dolly
| ash t |
 ash t World Chat Champion
| map |
 map Mr Calendar
 Posted: 17:22 - 25 Apr 2005 Post subject: |
Had a little problem with a hill start with pillion at the weekend.
With the pillion had to use a lot more revs than usual (solo) to get the bike moving at the clutch bite point.
I was a little lazy and didn't adjust the suspension so maybe that didn't help. It was also at the end of a long ride (2 hours). ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?
| cqueen |
 cqueen World Chat Champion
| mr jamez |
 mr jamez World Chat Champion
Well in the car I always use the handbrake unless it is only going to be a few seconds, quite a lot of wear on the clutch plus there is nothing to stop you if somebody drives up yer bum. Will do the same on the bike, it is the easiest and safest way to do it in my opinion!
Just wait till you can feel the bike/car trying to pull forward. Then let off the rear brake/handbrake and you will never stall (well er ) |
| RealNinja |
 RealNinja World Chat Champion
 Posted: 17:28 - 25 Apr 2005 Post subject: |
We have a little hump backed bridge not far from where we live, and you can only get one car through it at a time, so 50% of the time you have to stop for the traffic.
Problem with this is that the run up to the bridge is an incline too, so you have to be able to do hill starts!
I spent the entire afternoon with my missus practising on a nearby industrial estate till she got it right every time  ____________________ You will become my force of retribution. Where you tread, doom will follow. Go now and claim your destiny |
| bazza |
 bazza World Chat Champion
 Posted: 17:41 - 25 Apr 2005 Post subject: |
Interesting take on the situation: https://www.peterharris.org.uk/roadsafety/leftfoot.htm
If it's just me on the bike, I tend to go for the front brake and throttle on hill starts; when two-up, I prefer the rear brake as I generally need more revs to get moving so the right hand needs more movement available. ____________________ "That's it. You people have stood in my way long enough. I'm going to clown college."
'98 Ducati 750SS, '08 Suzuki GSX650F ©2004-2014, Bazza's Harmless Banter |
| westendboy7 |
 westendboy7 Nitrous Nuisance
 Posted: 18:12 - 25 Apr 2005 Post subject: |
Nice to see you got the new Suzuke Bazza. Hope all is well with it.  |
| Annabella |
 Annabella Like a person, only smaller
 Posted: 18:31 - 25 Apr 2005 Post subject: |
Hill starts with the extra weight are a lot more difficult as you need so much more throttle (depending on the size of the pillion of course).
I couldn't imagine trying to keep the bike steady using just the front brake and cluth I just don't feel balanced enough. I'd go and practice using the rear brake a bit if I were you - it's much easier in the long run (only problem I find is if said pillion decides to fidget when you're at a stand still with the rear brake and only one foot to the floor... ) ____________________ Avast! Pirates ahoy!
I did Cadwell!
www.bikepics.com/members/bella |
| bazza |
| shellshock |
 Posted: 19:23 - 25 Apr 2005 Post subject: |
Oh well, it looks like its back to basics then - its been awhile since this has happened, I'd got to the point of just not thinking about it, guess the extra weight is the problem.
Cheers Bazza, nice to know its not only me thats strange
On the plus side, I wasn't doing the penguin paddle today approaching a stop, and feel quite comfy now balancing on one foot. So much improvement there (someones got to big me up !)
Also my little fella (7) went pillion today for the first time, said he was shaking 1st time round the block, ended up going round 4 times, and still wanted more  |
 ..... Quote Me Happy
| ash t |
 Posted: 19:25 - 25 Apr 2005 Post subject: |
10 years time and he will be on an RS!!!!  ____________________ When You're Starting To Choke, Take Some Pills With Your Coke, Its Hyserical |
| westendboy7 |
| Will87 |
 Will87 Trackday Trickster
 Posted: 19:54 - 25 Apr 2005 Post subject: |
Try hill starts two up with a bike that you can't use first in and only has 26ish bhp. Thats fun . |
| shellshock |
 Posted: 20:19 - 25 Apr 2005 Post subject: |
- no thanks. I'd be there all day !!!!
You all make it sound so simple, it isn't, I know
I've had to call a friend before to come and help me turn the bike around so I could carry on my jolly - downhill.
I plan routes that avoid traffic lights on hills.
I've used up my entire swearing repertoire on my cbt with a kickstart CG, on a hill.
Only good thing is that I don't live in the Lake District anymore, or Buxton, places that contain many many hills.
I don't like hills/banks/mountains/inclines/upward gradients much. |
| Annabella |
| Frost |
 Frost World Chat Champion
 Posted: 20:17 - 26 Apr 2005 Post subject: |
Power isnt so much of an issue, gearing is!
I could hillstart up the side of a mountain on my 125 with a pillion, as it would pull away on the level without any throttle.
The VFR is a real bitch to hillstart with a pillion thanks to the 65mph 1st gear.
I normally overcompensate and end up revving the balls off it and slipping te clutch for miles  |
| Dom_ |
 Dom_ Points Mean Prizes
 Posted: 20:37 - 26 Apr 2005 Post subject: |
I'd cover the rear brake and release the clutch slowly until you feel it starting to bite, then give it more revs and a bit less clutch.
Once your used to it though, like i am on my bike, when pulling away up hills i just let off the rear and go straight away, the only problem i had with carrying a pillion was wheelying. Due to the fact my bike has a short wheelbase, a lot of revs means the front end will come up.
Practise makes perfect.  |
The last post was made 21 years, 187 days ago. Instead of replying here, would creating a new thread be more useful? |
