plugger147 |
plugger147 World Chat Champion
gsxrpeak |
gsxrpeak Trackday Trickster
plugger147 |
mchaggis |
mchaggis World Chat Champion
Posted: 22:11 - 27 Apr 2005 Post subject: |
Do look at Smoothrite, made by the same company. I don't know about you, but I'd prefer a smooth finish compared to a hammered effect finish on my bike frame. ____________________ I must not be a troll...
Mmmm, Guinness
Discovering the delights of Hammerite and a 3/4" brush. |
mr jamez |
mr jamez World Chat Champion
plugger147 |
brownoverall |
brownoverall Derestricted Danger
Posted: 02:09 - 07 May 2005 Post subject: |
Catching up with this a bit late, sorry - I hate to rain on the parade but Hammerite and Smoothrite are not oil or petrol resistant. Don't believe me - phone up their prized paint hotline and ask... It's a shame, cos the strength of Hammerite and Smoothrite comes from using ground glass in the pigment...
But all is not lost, as a modern solution offers itself. Before you stump up your spondulicks for proper stove enamelling, consider using twin-pack acrylic as a brushing paint... Think black Araldite.
Most good car paint suppliers like Morellis sell twin-pack, they just don't expect you not to spray it... Check out the correct mixing quantities carefully (ISTR it's 2 parts paint to 1 part hardener, but it's a few years and the little grey cells have more and more trouble finding each other...) and don't mix too much up in one go. The neat, unthinned paint is still quite a liquid finish compared to Smoothrite, so it goes on easily and leaves a nice smooth finish when brushed (a bit like old fashioned brushing enamel, if anyone remembers that...) Twin pack can be overcoated once it's gone off - depending on the type of paint and the mix, anything from 30 mins to overnight. Quick rub down with some 380-400 grit wet+dry, wipe down with thinners, second coat and you've got a rock hard, fuel-proof finish that resists stone chips and banging with a Number 2 micro-adjuster...
If you really want to kill the rust for good, after you've done your sanding/wire brushing/bead blasting, wipe down with thinners, then use a rust converter fluid on any visible specks of rust. Make sure you've sanded / wire brushed the surface of the metal to key the paint, though, or it'll chip easily. Then use a high-build rust-proof (zinc oxide) primer - just brush it and let it dry thoroughly overnight, preferably somewhere warm like the airing cupboard. (What d'yer mean, it's full of washing?). Give it a light sanding to key the surface (and remove any runs) with 380-400 grit wet+dry and continue as above. Having a slightly softer primer under a hard top coat acts a shock absorber and actually helps protect against stone chips.
Sorry to get all technical on you, but hey, that's what BOs do
Ride safe, ____________________ Brown Overall
(Pride & Clarke's veteran, BO 1st Class) |
ZRX61 |
ZRX61 Victor Meldrew
brownoverall |
Posted: 10:00 - 07 May 2005 Post subject: |
> Just remember that the fumes from 2 pack contain
> CYANIDE from the isocyanate base.. think Bhopal...
Rumbled. How the devil is an old BO going ter knock off enough of you youngsters ter liberate a decent Bonneville... ?
Seriously (a) this is very true and (b) doing the painting by hand in a well ventilated space (as opposed to spraying without a mask) is probably quite safe. Never did me any h-h-h-h-h-h-arm.
Ride safe - every cage on the road is a potential SMIDSY.... ____________________ Brown Overall
The last post was made 19 years, 35 days ago. Instead of replying here, would creating a new thread be more useful? |
