DanceLikeAMon... |
DanceLikeAMon... World Chat Champion
beasty1711 |
beasty1711 Nitrous Nuisance
Robby |
Robby Dirty Old Man
G |
G The Voice of Reason
DanceLikeAMon... |
Posted: 10:12 - 05 May 2005 Post subject: |
That all sounds promising, cheers!
I was going to get the bike serviced anyway, so I will let the mechanics take care of it. |
map |
map Mr Calendar
Posted: 10:48 - 05 May 2005 Post subject: |
Agree with comments above.
Symptoms you describe could be down to bike being stood for a period.
Would get a service for any bike new to me - change all the liquids and filters, check brake caliphers/pistons and pads, new set of plugs and as said oil cables. At least then you'll have a known starting point.
HTH ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger? |
Scotsman37 |
Scotsman37 World Chat Champion
Spazzy |
Spazzy Derestricted Danger
Method |
Method World Chat Champion
Posted: 13:16 - 05 May 2005 Post subject: |
I have exactly the same bike mate, same kind of milage.
What i would suggest is if you slip your hand past where your clutch cable enters its resting place, and have a fiddle about underneath the carbs you will find a kind of twisty nob thing. i duno how to explain it, its basicaly a circle on the end of a stick pointing downwards. if you turn that it will screw up and down depending on what way you turn it. Thats your idle adjusting screw and turning that will make your idle speed higher or lower, raise your idle speed a little and see if that helps. My guess is that it might be too far unscewed and causing there to be nearly no idle. ____________________ CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado
My Bikepics.com - No Brakes, No Gears... No Fear. |
DanceLikeAMon... |
G |
Kickstart |
Kickstart The Oracle
Posted: 14:12 - 05 May 2005 Post subject: |
As a very short term bodge for the choke.
Follow the cable down to the carbs. It probably goes in from the side (while the throttle cables go in from above), and probably has a 90 degree bend in it there.
Gently pull the 90 degree bend section away from the carb by 5mm~10mm. This pulls the choke on, and you might be able to seat the cable end such that it holds it on.
I would not recommend doing this for long, nor trying it when riding, but it might help if you have problems starting the bike or want to let it warm up a second while you put your lid on.
The seal you can see is probably just the dust seal not the actual hydraulic seal.
DanceLikeAMon... |
ZRX61 |
ZRX61 Victor Meldrew
Nath |
Nath World Chat Champion
DanceLikeAMon... |
Bomberman |
Bomberman World Chat Champion
Posted: 15:20 - 05 May 2005 Post subject: |
I'd get it to a reasonable idle speed before it gets too cold tbh mate. You don't want to be fiddling with it when you can't get the bike to start at all tomorrow. I did that and it was a real pain in the arse trying to get it back going again. ____________________ 'Allo! My name is Inigo Montoya, you killed my father, prepare to die!
'89 TZR 125 - '94 GPZ500s - ZK3 GSXR600 Alstare |
DanceLikeAMon... |
extreme3d |
extreme3d World Chat Champion
DanceLikeAMon... |
DanceLikeAMon... |
The last post was made 19 years, 36 days ago. Instead of replying here, would creating a new thread be more useful? |
