| Author |
| illusion |
 illusion Scooby Slapper
 Posted: 09:24 - 23 May 2005 Post subject: More security |
Hey all,
As I live in flats, I have to park my motorbike in our car parking space in front of my girlfriends car. I don't have anything to lock it to so if someone is going to want to nick it they won't have much trouble. Currently I put a cover over it and I have a meaty Oxford chain going through the front wheel/disc. Now, it's not the most nickable bike (GS500 ) but i'm still a bit paranoid it's going to get nicked. Could anyone suggest some more security I could put on? Unfortunately I can't drill an anchor in to the ground as we don't own the parking space.
Cheers, Dan |
| Back to top |
| Itchy |
 Itchy Super Spammer
 Posted: 10:21 - 23 May 2005 Post subject: |
The concrete block solution , learned from a mate who used to live in Hong Kong.
Get 2 ground anchors £15 each those that you cement into the ground , buy a couple of those cheapo plastic boxes really big ones used for general storage the cheaper the better as you will destroy them £1.50 each. ,
Now get a mate with a car , and go round to a builders yard or a ready mix concrete place (sometimes they bring it round to you)
and fill the boxes with concrete and put the ground anchors into the drying concrete , and leave it for a day or so hack off the plastic boxes and you have two solid blocks of concrete depending on how big you made them , which you can secure your bike to , if you make some steel reinforced concrete even better... £2 for the concrete £3 for some old steel £10 for a couple pints for an engineering student to build the reinforcement for you
Do not make gigantic cubic metre blocks as you will not be able to move them.
reinforced = better as a bloke with a big hammer can't hit it and crack it easily.
now buy yourself a hand truck , those L shaped things with two wheels that people who move lots of stuff have , and you can bring them into the house when not used and out when you park them £20 , buy one depending on the size and weight of the blocks you want to use.
Since you also have a car its even better make L shaped blocks with simple moulds and park the car over the bits that stick out with the wheels on the concrete slats ,
which serves as an OK hash of a ground anchor which is pretty cheap , however the weakness moved away from a bloke with a van lifting it away into the back of his van to the strength of your chain , but since it is your home immobile security you can use gigantic ship chains to lock it up.
BUT before you even consider this , calculate the weights involved and where you will store the blocks if asked to move them when not in use , |
| Back to top |
| Groove |
 Groove World Chat Champion
 Posted: 10:40 - 23 May 2005 Post subject: |
someones done this before...  |
| Back to top |
| ghostgirl |
 ghostgirl Nova Slayer
 Posted: 11:40 - 23 May 2005 Post subject: |
Yep ground anchors,chains and bucket of concrete  ____________________ The most wasted of all days is one without laughter.
www.bikepics.com/members/ghostgirl |
| Back to top |
| Bendy |
 Bendy Mrs Sensible
| Back to top |
| biggerjohn |
 biggerjohn Spanner Monkey
| Back to top |
| map |
 map Mr Calendar
 Posted: 12:34 - 23 May 2005 Post subject: |
I've heard good things on BCF about the PageAlert pager alarm (it's just a dedicated radio pager, it you want an alarm that's another item).
They're from M&P for around £40 click here (BTW someone on eBay had them for the same price).
Thinking of adding a PageAlert myself. Already have the Cheetah alarm already fitted (see eBay).
HTH  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| Back to top |
| gimpy limp |
 gimpy limp Nearly there...
 Posted: 13:57 - 23 May 2005 Post subject: |
it'll buckle them trolley jacks that much weight, my manta engine bucklet the wheels of my trolley jack so did the bike engine. Granted they were only 20 quid trolley jacks. personally I don't think that'll make any difference, nice big bolt/chain cutter and they'll have it off like that wether it's connected to an elephant or jsut your wheels.
Can them thngs be lifted into a van or something by a group of 4/5? ____________________ -=[Sam/b]=- cx500's the only way to travel, we do it in style just like jimmy saville
msn addy - [email protected]
https://pre-auto.com/cx500/rat_and_survival_gallery_2006 |
| Back to top |
| ali-b |
 ali-b Trackday Trickster
 Posted: 14:13 - 23 May 2005 Post subject: Flat Management Companies |
I live in flats too, so not quite owning the parking space. A management company (normally you pay them a sum each year/month for shared maintenance) should exist to help you deal with this, and you can normally ask them for permission to install a ground anchor. They may ask you to provide photos of the ground anchor and describe how it will be installed, and may also get you to put the anchor in a different spot in the carpark and at the very worst they'll say no...but its always worth an ask...
I was quite lucky in that my space is next to earth rather than concrete, so I used an auger to drill down about 6 feet for the main attachment, then twice from the surface to about 3 feet at a 45 degree angle, meeting up with the centre of the 6 foot hole to provide a kind of Y shape anchor (so it wasn't just a cylinder of concrete), each hole was about 8 inches or so in diameter. Poured concrete into the holes, dropped a chain down the centre hole, and attached the anchor to the chain...the 2 outer holes were covered over with earth again, so you wouldn't even know they were there...and in fact grass has regrown over them...
Alex |
| Back to top |
| dainesefreak |
 dainesefreak World Chat Champion
 Posted: 14:28 - 23 May 2005 Post subject: |
Something else I've just done too is put a mobile on my bike on a pay as you go SIM and joined www.followus.co.uk. You only buy credits, no subscription and it seems to work quite well. We're not talking pin point accuracy here but it does give you enough info to get a search in the right place going. |
| Back to top |
| bish777 |
 bish777 World Chat Champion
| Back to top |
| G |
 G The Voice of Reason
| Back to top |
| illusion |
| Back to top |
| 0ni |
 0ni World Chat Champion
 Posted: 16:37 - 23 May 2005 Post subject: |
If someone had a really wicked sense of humour you could to the concrete block idea with something like a plant pot, leaving some top soil to disguise it. Try and see someone move it then
If Carlsberg made plant pots.. ____________________ Its a lovely day, just wait until some bastard spoils it. |
| Back to top |
| Bendy |
 Bendy Mrs Sensible
| Back to top |
| Milo |
 Milo World Chat Champion
 Posted: 16:48 - 23 May 2005 Post subject: |
I lock my bike around a friend's front car tyre when parking there.
Means they can move if need be and lifting the front of a car/releasing handbrake puts another obstacle in their way. ____________________ Shaft drives rule.  |
| Back to top |
| sickpup |
 sickpup Old Timer
| Back to top |
| quik_d |
 quik_d Could Be A Chat Bot
 Posted: 18:33 - 23 May 2005 Post subject: |
you would think a loud alarm would deter them, but its not the case nowdays as noones pays attention to them! i had my arrow silencer UNBOLTED from my bike in the student car park at lunchtime-ish with the alarm going off, (and i know it went off cos it had some memory thing). Public place, really loud alarm in their ear and still they took it! chav basta**ds!!! it was never as good afterwards with different silencer on it  ____________________ LOOK AT DAT M8 WELL LUSH A PARROT INT IT |
| Back to top |
| illusion |
| Back to top |
| king756 |
 king756 Nitrous Nuisance
| Back to top |
| map |
 map Mr Calendar
 Posted: 10:21 - 24 May 2005 Post subject: |
| Back to top |
| map |
 map Mr Calendar
 Posted: 10:32 - 24 May 2005 Post subject: |
Like the idea and it seems affordable. Do you leave the phone on the bike? If so, have you fixed up a 12v charger? ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
| Back to top |
| illusion |
 Posted: 10:21 - 25 May 2005 Post subject: |
Thanks. I think I might go for one of those eBay Cheetah alarms. I'm not too bothered about making insurance cheaper as I have a pretty cheap quote as it is! And it's mainly so I can hear it if anyone tampers with it when it's outside my flat.
Is it hard to fit one of those? Bearing in mind I am a mechanical n00b  |
| Back to top |
| map |
 map Mr Calendar
 Posted: 10:34 - 25 May 2005 Post subject: |
| Back to top |
| Liverpoolrobb... |
 Liverpoolrobb... Crazy Courier
| Back to top |
The last post was made 21 years, 112 days ago. Instead of replying here, would creating a new thread be more useful? |
