| gimpy limp |
 gimpy limp Nearly there...
 Posted: 16:56 - 23 May 2005 Post subject: chain redesign? |
https://img290.echo.cx/img290/9328/chain4db.jpg
just a thought but wouldnt lots of high stength 'strands' of cabling be alot better than a standard chain? it's flexible enough to go through the frame. A normal chain you can cut with bolt cutters pretty easily, with high tensile strands they compress into each other as the bolt cutters tighten down (you've gotta try and mentally picture it in your head) so the surface area the bolt cutters are pressing on spreads the load out as well as gets smaller.
the middle one isn't going to be flexible enough to physically carry with you on the bike (should wrap around the bike easily enough at home or in the garage). So why not make them in the shape of a chain (like the 1st pic)
I think these things use a similar weave design (obviously much much thicker and you don't want the strands quite as rigid and compact as what they use):
https://www.nailbat.com/albums/house/house008.sized.jpg
I know it's not something you can make at home yourself ____________________ -=[Sam/b]=- cx500's the only way to travel, we do it in style just like jimmy saville
msn addy - [email protected]
https://pre-auto.com/cx500/rat_and_survival_gallery_2006 |
| feef |
 feef Energiser Bunny
 Posted: 17:01 - 23 May 2005 Post subject: |
theoretically I don't think your design has much against it..
small points to consider..
it would tend to having circular links, or else, it might put the outer strands at the ends of the eliptical loops under more tension than elsewhere. Would perhaps need to get specially made lops that allow the elliptical shape to be maintained while alowing an even tension throughout the strands.
there's also the method of joining the ends of each individual strand within your loops.. else, there will be a single point of failure in every single link.
address those points, and manufacturing costs and you could have something.
a ____________________ Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating |
| gimpy limp |
 Posted: 17:05 - 23 May 2005 Post subject: |
can't imagine it would be cheap to manufacture either those normal bike chains are like 80 quid cheapest in the bike shops around here. Would need special machines to do it if their was a way to address those weaknesses. ____________________ -=[Sam/b]=- cx500's the only way to travel, we do it in style just like jimmy saville
| ghostgirl |
 ghostgirl Nova Slayer
 Posted: 17:10 - 23 May 2005 Post subject: |
Good idea in theory. But same old story if someones going to pinch your wheels they will hack through whatever! ____________________ The most wasted of all days is one without laughter.
www.bikepics.com/members/ghostgirl |
| feef |
| Itchy |
 Itchy Super Spammer
The last post was made 21 years, 118 days ago. Instead of replying here, would creating a new thread be more useful? |
