imadoofus |
imadoofus Renault 5 Driver
Posted: 02:00 - 09 Jun 2005 Post subject: ermmm.. why does this circuit thingy end in mid air? |
hey all,
I am getting better at this.
I am a man on a mission and armed with a multimeter, a good amoutn of insulation tape, umm a nail file, wd40 and other such knick knacks to tackle the 2 cyclinders not firing issue some of you might remember.
Tomorrow I take it out and clean all connectors to try and get this fixed.. If not its off to the garage and more $ for me
the stupid question for toda is this. In the attached electric diagram, the fat red wire from the regulator just goes straight and stops nowwhere. Please refer to diagram. can someone explain this.
And i saw that the red wire was actually unconnected also when i opened up the side cover. Wasnt sure if it was a loose contact or not.
can someone please explain that? |
mr.z |
mr.z World Chat Champion
Posted: 02:24 - 09 Jun 2005 Post subject: |
From the diagram (not easy to be 100% sure) it does indeed look like it goes nowhere...
Thing is manufacturers will use a wiring loom for several models of the same bike sometimes, or even between 2/3 models... the result is wires that mysteriously go nowhere... costs less to mass produce, even if they are not useing 2/3 wires 30% of the time...
Can you get a higher res selection of it? ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
imadoofus |
imadoofus |
mr.z |
imadoofus |
Posted: 04:43 - 09 Jun 2005 Post subject: |
[quote="zero"]Is yours an RJ? (whatever that denotes)
This
https://www.xj-forum.de/schaltplaene/xj650_maxim/wiring_diagram.pdf
/quote]
ya its an RJ
and the second confusing part is that the first owner did some rewqiring that I have no clue about and the ignition switch has ben bypassed. So i am not really sure if its a reduntant wire or something that came loose.
Guess i will poke around and see
thanks |
The last post was made 18 years, 327 days ago. Instead of replying here, would creating a new thread be more useful? |
