half yayyyyy.. my baby is 80% ready..still some queries..
imadoofus
PostPosted: 22:59 - 09 Jun 2005    Post subject: half yayyyyy.. my baby is 80% ready..still some queries.. Reply with quote
hey all,
DUI when it works is soo satisfying..
turns out 1&4 not firing wasnt the coils.. i checked the coil, the wiring all the way to the tci and the pickups.... got depressed cos i didnt know what frikkin tool i had to use to get the damn pckup cover over.... so poked around with a multimeter in the tci.. and ws running out of ideas of what to check when i decided to check the ht leads.
and one of them was broken.. yippee...
so cut and replaced it and the baby runs a lot better..
still not full power.. and 1&4 header pipes get warmer than before.. I had cleaned the sparks.. but i dont know how good it was.. i cleaned with sandpaper as it was all oily and the plug was looking rather disgusting.
1. I have new plugs but i haev no means to check the gap other than a visual approximate comaprison. Is that alright for sometime?
2. Also i screw it on manually.. I never really understood what 1/4 twist meant.. is that like 90 degrees which would make the plugs really tight. So what happens if the tightness is nto corect?
and hey thanks to all who helped.. stinky, keith etc especially and everyone else.
Nath
PostPosted: 23:03 - 09 Jun 2005    Post subject: Re: half yayyyyy.. my baby is 80% ready..still some queries Reply with quote
If they're not in tight enough there's the possibility they could be blown out Shocked Not sure how likely this is, but I wouldn't fancy risking it...
Hard livin', hard luck.
J.K.R
PostPosted: 23:04 - 09 Jun 2005    Post subject: Reply with quote
Ive never really bothered with plug gaps although i know i should, and im sure its 1/8th turn (45 degrees) but just nip it in really (dont go nuts with it though snapped plugs are an absolute pain in the ar*e)
hth Thumbs Up
www.oldskoolsuzuki.info
imadoofus
PostPosted: 23:37 - 09 Jun 2005    Post subject: Reply with quote
And the gap? I have no idea how much it is exactly.does an incorrect gap affect much?
ZaphodBeeble
PostPosted: 00:19 - 10 Jun 2005    Post subject: Reply with quote
I've never really bothered with plug gaps and my plugs have always been fine.
Make sure you screw them in quite tight though, especially if they are new as they have a washer on them that needs to be squashed down to make a good seal with the cylinder head.
I forgot to tighten up the sparkplug on my nsr125 a few months back, I had just pinched it up gently and not cranked it right up for some reason which escapes me now. Confused I rode it for a few miles, probably about 30 or so before the bike started to sound a bit odd. It seemed down on power and I only really noticed it when I was going up a really steep, winding mountain road. I got to the top and stopped the bike to check it over. When I looked at the spark plug it was hanging onto the engine by its last 1 or 2 threads! The bike was still running like this! Bloody ridiculous, but that's a honda for you. Razz
Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders.
PostPosted: 03:23 - 10 Jun 2005    Post subject: Reply with quote
You'll probably be ok with the gap, 4-strokes and CDI ignitions are not so fussy, you would have to get it right with a points ignition 2-stroke though. They are usually set to 20 thou" from the box which is generally about right (well any NGK plug I have used has been).
Assuming they are brand new plugs with compression washers, I usually put them in finger tight then tighten them another 90 degrees using a plug spanner. This makes the compression washer squash down by the right amount and is a more accurate way of tightening threads than a torque wrench (a 90 degree turn tightens the plug down the threads by a fixed distance regardless of any muck in the thread, how oily they are etc.) . In any case, a 1/4 turn off finger tight shouldn't strip anything that wasn't already broken.
Glad to hear you are making progress.
imadoofus
PostPosted: 16:24 - 10 Jun 2005    Post subject: Re: half yayyyyy.. my baby is 80% ready..still some queries Reply with quote
imadoofus wrote:
hey all,
I think I meant DIY Very Happy
PostPosted: 16:50 - 10 Jun 2005    Post subject: Reply with quote
I think I meant DIY
Made perfect sense to me how it was originally Wink
The last post was made 18 years, 325 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.57 - MySQL Queries: 17 - Page Size: 60.67 Kb
