| R4nger |
 R4nger World Chat Champion
 Posted: 11:18 - 17 Jun 2005 Post subject: My first spray job |
For a Suzuki GS500E
Lacquer drying. |
| Chr!S |
 Chr!S Nitrous Nuisance
| R4nger |
| Phoenix |
 Phoenix Twisted Firestarter
| Kye |
 Kye Scooby Slapper
| Phoenix |
| Simonbt |
 Simonbt Nitrous Nuisance
 Posted: 08:43 - 21 Jun 2005 Post subject: |
Sand down between primer coats. You can also do it between top coats but you need the finest paper. You're best off using Tcut.
I'm currently respraying my bike. I've just finished reparing all the panels and now im priming them. When you spray out of a can the paint will end up pretty lumpy and rough when it drys (tiny little bumps which stop it going shiny). If you get 1600 or 1200 grit wet and dry, get it soaking wet and then run it over the primer (dont rub, remember you are only smoothing it down) the paint will become really smooth. You will find that you will rub all the way through the coat in places so just respray and keep repeating.
Do exactly the same with the top coats, but with a little difference. Do about 2-3 coats, sanding between each one. Remember you are only sanding to smooth it off. Once you cant see the primer after you have sanded give it one more coat, wait for it to dry and attack it with tcut. You can get a good finish with a can but it takes hard work.
Or, do what im doing. Do all the prep work, fibreglass it, sand it, prime it, sand it again and get it smooth. Then send all the panels and tank to a spray shop and get them to top coat it for you. I was quoted £75 to spray all my panels red. I'll post some pictures when i've got them done. sorted  |
The last post was made 21 years, 151 days ago. Instead of replying here, would creating a new thread be more useful? |
