Front brake disc
dibbster
PostPosted: 12:28 - 07 Jun 2005    Post subject: Front brake disc Reply with quote
I was checking my front brake pads this morning when I noticed there was quite a bit of sideways play on the disc.
It would seem that the five rivet bits (circled in red) are loose and the one with the arrow next to it has the split washer missing all together.
Is it repairable? or do I need to raid the piggy bank for a new disc?
Suzuki RF 600 - The two wheeled Testarossa (Deceased)
Suzuki GSXR - Now stops on a sixpence; SBK3's Thumbs Up
www.bikepics.com/members/dibbster
PostPosted: 12:50 - 07 Jun 2005    Post subject: Reply with quote
It is a floating disk and is meant to have some sideways movement.
The missing washer locating that bobbin is more worrying.
dibbster
PostPosted: 12:57 - 07 Jun 2005    Post subject: Reply with quote
Compared to the other front disc there is alot of sideways movement (around 1/4 inch each way)
Is it possible to replace the washer and tighten the bobbins to reduce the sideways movement?
dibbster
PostPosted: 14:55 - 20 Jun 2005    Post subject: Reply with quote
Well upon removing the disc from the bike I found two missing washers and three futher broken washers. Crying or Very sad
However the disc is still considerably thicker than the 4mm limit so I decided to replace the bobbins.
If anyone ever wants bobbins; Trade Direct at Sheffield (Thanks Kickstart), worked out at £25 to replace the bobbins. Thumbs Up
Only took an hour with an angle grinder and three hacksaw blades to chop out the old ones.
So disc fixed, new pads to fit and sunny weather. Pefect. Thumbs Up
PostPosted: 18:12 - 20 Jun 2005    Post subject: Reply with quote
Glad you got it sorted out.
Dom
PostPosted: 19:47 - 20 Jun 2005    Post subject: Reply with quote
Was just about to post the same thread myself. Thanks for info and will give the guys in Sheffield a call.
dibbster
PostPosted: 22:26 - 20 Jun 2005    Post subject: Reply with quote
Map link for Trade Direct.
The last post was made 21 years, 153 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.63 - MySQL Queries: 14 - Page Size: 53.68 Kb
