Security
killa
Won't Shut Up
PostPosted: 16:12 - 28 Jun 2005    Post subject: Security Reply with quote
I have moved into my flat, everything is going well.
I couldn’t get the bike in the lobby area so the kind people who own the building have allowed me to use their lock up, its basically by the side of the building a little walk from my flat.
See diagram…..
https://i7.photobucket.com/albums/y278/Killa127/untitled.jpg
The gate is fairly strong like metal grid type (sorry hard to explain, this is locked with a hardened steel padlock.
The container is like one you use for shipping, with a large iron bar to lock in place, this is also locked with the same padlock.
The bike is data tagged, has steering lock, large oxford chain and a disc lock.
Is this enough, or do you think I need some kind of audible alarm?
Any suggestions for this would be great
Thanks
Suzuki
Roger
PostPosted: 16:16 - 28 Jun 2005    Post subject: Reply with quote
Sounds like more than enough mate.
It's probably more secure than most garages!!
<Simple> no I'm shaven Jon Razz
<Simple> it is a big enough hole.. I'll leave it now
Ride: 1999 Suzuki GSXR600 (yellow/black) IRC: Stats - Relationship Map
killa
Won't Shut Up
PostPosted: 16:19 - 28 Jun 2005    Post subject: Reply with quote
That makes me feel better, I have always said, if someone really wants it, they will get it.
After 3 bikes being stolen I have learnt a lesson.
The padlocks I have a called ‘hardened’ what exactly does this mean, that you will need something more than bolt cutters??
daz|n00by
The Internet
PostPosted: 16:21 - 28 Jun 2005    Post subject: Reply with quote
sounds like it would be a lot of hassle to get at it and most theives wouldnt have the time imo,
"Its Better To Burn Out Than Fade Away!!!!!!" "Lifes a bitch and then you Die"
"I`m a tool, one with just enough intelligence to know it, just enough spirit to resent it...but not enough backbone to do anything about it. " Siggi 2006 pure class. Smile
Suzuki
Roger
They'll be manufactured with case hardened steel, rather than standard steel.
Makes it more brittle, but damn hard to cut through. You'd need more than some standart bolt croppers.
map
Mr Calendar
PostPosted: 17:01 - 28 Jun 2005    Post subject: Reply with quote
For in your flat a PageAlert pager alarm might be an idea.
I'm thinking if you can't see the lockup from your flat you might not hear anything as well.
The PageAlert is just a dedicated radio pager, it you want an alarm that's another item.
They're from M&P for around £40 click here.
Failing that, in the lockup a cheap PIR garage alarm with sounder and a baby monitor, the baby alarm receiver in your flat.
Just some thoughts Smile
killa
Won't Shut Up
PostPosted: 17:09 - 28 Jun 2005    Post subject: Reply with quote
I thought of the baby intercom thing, do you think the signal would reach??
Cheers for the info mate Thumbs Up
gimpy limp
PostPosted: 17:10 - 28 Jun 2005    Post subject: Reply with quote
could fit something that makes a noise to the inside of the contrainer door like a dozen windchimes from poundland!! if it's opened without knowing it's their gonna make a lot of racket in theory? maybe Rolling Eyes Confused
-=[Sam/b]=- cx500's the only way to travel, we do it in style just like jimmy saville
msn addy - [email protected]
https://pre-auto.com/cx500/rat_and_survival_gallery_2006
gimpy limp
PostPosted: 17:12 - 28 Jun 2005    Post subject: Reply with quote
actually you can buy proper 2 way radios on ebay really cheap that have sound activated things on them!! I used one in my car worked decent but some outside noises would set it off. But inside a metal container is ideal as the noise from the door will set it off. They'll work up to like 3 miles away the cheap ones. Think I paid 30 quid for a nice one. Just need a bunch of rechargeable batteries left on charge.
gimpy limp
PostPosted: 17:21 - 28 Jun 2005    Post subject: Reply with quote
that's the kind of thing i think it was that I had (I think mine was motorola though):
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=72405&item=5784736143&rd=1&ssPageName=WDVW
lays dorment until it hears a sound then turns itself on, kept mine on the tv or by your bed.
map
Mr Calendar
PostPosted: 17:42 - 28 Jun 2005    Post subject: Reply with quote
gimpy limp wrote:
...you can buy proper 2 way radios...
Ah, just thought. Metal container like lockup.
So may act as a faraday cage.
Radio signal may be non existant or very poor.
So that might put the dampers on the baby alarm/radio idea. However, expect pager may be reactivated if bike moved so get a signal.
Just my thoughts. Could always suck it and see WRT radio signal quality.
The last post was made 21 years, 85 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.84 - MySQL Queries: 17 - Page Size: 78.31 Kb
