Oh pi$$ it!!"!**
killa
Won't Shut Up
PostPosted: 09:34 - 13 Jul 2005    Post subject: Oh pi$$ it!!"!** Reply with quote
Bought two tyres last week, Bridgestone Battlax, if you remeber yesterdays post of the glass all over the road where i put my bike in a lock up. Well, the glass i swept up, but as i put the bike in i checked the tyres.
I can see what looks like the head of a nail, one of those ones with the small head not a flat one.
WTF can i do??? I dont get paid for ages and i am all out of money.
LustyLew
PostPosted: 09:54 - 13 Jul 2005    Post subject: Reply with quote
Get em plugged. (About £15 if I recall).
I used to commute on my old bike every day. That had Battlax's on, at any one time, I'd have 2 plugs and at least 3 nails in them. Rarely did over 50 so I took the chance.
Oh, I'd suggest 'Tyre Slime' too.
SteWhit
PostPosted: 09:55 - 13 Jul 2005    Post subject: Reply with quote
Remove the nail and get some tire slime - it works for a quick repair job until you can afford to have the puncture fixed. That only costs like £15 to fix punctures tho...
killa
Won't Shut Up
PostPosted: 09:57 - 13 Jul 2005    Post subject: Reply with quote
Crikey, I didn’t know there were any options at all.
Cheers guys.
What the hell is a plug, and does it only work at low speed then?
Puncture repair sounds good, how does that work?
If I left It in the tyre, what would happen?
SteWhit
PostPosted: 10:01 - 13 Jul 2005    Post subject: Reply with quote
If you leave it in chances are it'll go flat - slowly - Plugs are small bits of rubber they put in the hole to plug it - not too sure if they are a permanent fix or not tho. Where is the nail? If it's in the centre of the tyre they can fix it - if it's the side your in trouble.
Suzuki
Roger
PostPosted: 10:21 - 13 Jul 2005    Post subject: Reply with quote
A plug is a permanent fix if done properly.
I had a massive bolt through my rear tyre about a week after it was put on. Took it to the garage, and they fixed it for me. Took the tyre off, plugged it from the inside, put it back on - good as new!
I've done 155mph on the plugged tyre, without consequence.
Go get it fixed!
<Simple> no I'm shaven Jon Razz
<Simple> it is a big enough hole.. I'll leave it now
Ride: 1999 Suzuki GSXR600 (yellow/black) IRC: Stats - Relationship Map
killa
Won't Shut Up
Yeah pretty much dead centre.
It is a very small one.
Suzuki
Roger
PostPosted: 10:26 - 13 Jul 2005    Post subject: Reply with quote
When you take it to be plugged they'll bore the hole out to be 3mm wide! Very Happy
paulthewitt
PostPosted: 10:45 - 13 Jul 2005    Post subject: Reply with quote
you my friend are unlucky!
sorry to hear the bad news. maybe plug it and ride carefully
PostPosted: 11:00 - 13 Jul 2005    Post subject: Reply with quote
There are limits on what can be repaired, but with a single small puncture in the middle you should be fine.
What they use looks like a small cocktail umbrella, with the fan out bit being rubber and the stem being part metal and part rubber. They bore the hole out a bit, thread the stem through the hole and pull it through so the umbrella bit surrounds the hole. It is then all bonded in place.
I think it is against the British Standards to repair a Z rated tyre, but people will ignore that and you probably have an H rated tyre anyway.
If you are lucky the it is not actually a nail or is just the very end and has not gone through.
killa
Won't Shut Up
PostPosted: 11:10 - 13 Jul 2005    Post subject: Reply with quote
Well nice!!
Just been out for a fag, I had another look at the thing, I picked at it with a key and it turned out to be a bit of swarf! Thumbs Up
Cheers for all the info
The last post was made 20 years, 314 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.29 Sec - Server Load: 8.36 - MySQL Queries: 17 - Page Size: 75.29 Kb
