Did I learn something new tonight ?
The Old Geeza
Back in my day...
PostPosted: 22:22 - 14 Jul 2005    Post subject: Did I learn something new tonight ? Reply with quote
Don't forget, I'm new to 'real' biking in every aspect.
I went out for a 'breeze' tonight on my own (as I do from time to time), just to get some more experience riding my bike. OK, it's only a 250 but I enjoy riding it.
I'm actually afraid of banking the bike because I always fear the tyres will lose their grip and the bike will simply 'disappear' away from me.
However, tonight I noticed that if I push the steering in the OPPOSITE direction to where I'm going, the bike actually banks even further into the turn I'm actually taking. That is, if I push the steering to the left when I'm actually banking to the right, the bike actually drops further to the RIGHT. Strange, but I actually felt more in control of the bike, and the more I did it the more the bike seemed to respond. I felt as though I really didn't need to bank the bike as low as I thought in order to take a corner or roundabout. It was very exhillarating.
Am I doing something wrong? Or have I discovered something all you 'real' bikers are already doing?
No sarcasm please. I'm a novice to biking and just willing to learn.
Horse Power was safer when the Horses had it!
Bendy
Mrs Sensible
PostPosted: 22:24 - 14 Jul 2005    Post subject: Reply with quote
Countersteering. Thumbs Up
Something instructors generally fail to mention, but we all do subconsciously (otherwise you wouldn't get round corners). But doing it consciously has advantages too, as you've just discovered.
mistergixer
PostPosted: 22:28 - 14 Jul 2005    Post subject: Reply with quote
It's called countersteering, and it's how bikes turn when moving above a certain speed.
I don't understand the science, but i know it works.
It is amazing how few people understand/know about it. 2 blokes at my work have 30+ years of biking experience between them and they refused to believe me, then they went out and tried it.
The amazed look on their faces told me everything!!
Space Monkey #7
White Noise
Mr Dudwee
PostPosted: 22:43 - 14 Jul 2005    Post subject: Reply with quote
there are two types of countersterring
passive - where you push the inner side of the handlebar
active - where you pull the outer handlebar
Good on you for realising whats going on Thumbs Up
now find a roundabout and countersteer you nads off and get you knee down! Laughing
WN
Buy my wife: 96' Yam XJ600s (Diversion)
Wing Commander White Noise - SE Clique
Riding Tip #86: See God, then back off a bit: Problem is i haven't seen god yet, just a close up of tarmac on revett straight
The Old Geeza
Back in my day...
PostPosted: 22:48 - 14 Jul 2005    Post subject: Reply with quote
Gets a bit 'scarey' though, sometimes, especially if you've got a sharp left then a sharp right and you actually push the steering in completely the opposite direction to which you're going.
Feels good though. I love my bike but I'm still frightened of my tyres not gripping and me falling off, with the bike flying off in the opposite direction of my body.
I'm not talking about 'knee down' stuff here. That's something I haven't even got the guts to do. Just normal, everyday riding 30, 40, 50mph stuff.
Is this just something I need to put more trust in? IE: I need to put more trust in my bike and believe in my bike's ability to stick to the road.
Sorry if I seem a bit of a novice. But I am. But I'm also beginning to really enjoy the experience. And I love riding my bike.
Zoffo
PostPosted: 22:53 - 14 Jul 2005    Post subject: Reply with quote
Sooner or later your gonna find yourself going into a corner a tad too hot. That's the time to remember counter steering. The more you activly push the bars counter to the turn the more the bike will lay down and the tighter you make the corner.
And most half decent bikes will lean much further than most people got the balls for Mr. Green
https://hyperbikes.forumsplace.com/
Quote Me Happy
PostPosted: 22:54 - 14 Jul 2005    Post subject: Reply with quote
Just make sure your tyres are nicely warmed up and the road surface is good and put faith in your tyres.
You'll be amazed at how far you can crank the bike over. What tyres are you running btw?
White Noise
Mr Dudwee
Thats what i love to hear!
TBH getting my knee down gave me the trust in my tyres and the fact i could lean a bike over that far, this is only on a roundabout at approx 30 mph.
how you ride should be the way you want it to be! enjoy it! Thumbs Up
WN
Fruit'n'nut
PostPosted: 22:56 - 14 Jul 2005    Post subject: Re: Did I learn something new tonight ? Reply with quote
Not at all, counter-steering is something you should practise and familiarise yourself with - get used to gauging how much pressure you need or how quickly to turn the bars to get the bike to turn "just so" Thumbs Up
Be smooth, be progressive Thumbs Up
Something else that occurred to me in reading your post: you're afraid of banking the bike over. Does the bike feel nervous or vague beneath you while negotiating a corner?
First of all, check your tyre pressures are set to whatever is recommended in your bike's handbook.
If the tyres are okay, try getting your speed right down before you start to turn into a corner.
Once you initiate the turn/enter the corner, crack the throttle open just a little, so the bike is driving round rather than coasting or still slowing.
Exclamation Gear selection is important here too - you want to be in a gear low enough so that a small throttle opening will produce nice clean drive. If you're in too high a gear, you won't achieve the same effect ....
The idea of this process is to make the bike feel settled. If you're still slowing as you turn, you're loading weight onto the front tyre - which might not make you feel comfortable as a new rider. The gentle drive produced by opening the throttle shifts the weight of you and the bike off the front tyre, leaving it to deal with steering input and hopefully helping you to feel happier about what you're feeling beneath you Thumbs Up
Hope this helps - it helped me a little while back Smile
Power Ranger Very Happy
The Old Geeza
Back in my day...
PostPosted: 23:10 - 14 Jul 2005    Post subject: Reply with quote
Thank you - Everyone. Keep the replies coming. Everybody's reassurance is heart-warming.
I can't wait to go out tomorrow night and try again.
In reply to 'Fruit'n'nut'...
My back tyre is well squared off, I've known that since I bought the bike. But I'm having a brand new rear tyre fitted next week. Im reliably informed that this will substantially improve my bike's performance and handling when cornering and banking.
Thanks for taking the time to reply.
Fruit'n'nut
PostPosted: 23:15 - 14 Jul 2005    Post subject: Reply with quote
A new tyre will make things feel a lot better Thumbs Up
You're welcome. It's what we're all here for isn't it?
.... well what you're all here for anyway - my pearls of wisdom and sagacity Very Happy Wink
The Old Geeza
Back in my day...
Sorry for late reply 'Joe'
Got Pirellis
Now't wrong with front tyre - almost brand new. But must get a new one on the rear. Well squared off. New tyre to be fitted next week.
PostPosted: 23:45 - 14 Jul 2005    Post subject: Reply with quote
Not sure how you would exactly describe it in terms of centripetal force etc. but.. If you ever need a demonstration of what is happening, get a pushbike wheel and hold on to the wheel spindle in both hands. Now get an assistant to set it spinning.
With the wheel spinning try turning it from side to side and see what happens.
NY_Sniper
PostPosted: 02:01 - 15 Jul 2005    Post subject: Reply with quote
i found countersteering noticed on a long corner and was wondering y i was pushing the right bar going round a right hander but then i thought about it and the science makes sence and it gets me round corners 20 mph faster now Smile my chicken strips are getting smaller i never understood y ppl like twistys Smile i do now RazzRazz
That Dot On The Horizon .... Its Me
> Kawasaki ZX7R (Betty Jnr) <> Suzuki GS500e in pieces (Bitch) <> Suzuki GS500e (Martha) <>
Jamie_ducati
PostPosted: 02:57 - 15 Jul 2005    Post subject: Reply with quote
Doesnt biking just never cease to excite?
Jamie
Time for eDUCATIon
Sheepy1209
PostPosted: 07:59 - 15 Jul 2005    Post subject: Reply with quote
Like TOG I'm completely new to biking, and as with many others my instruction centred entirely on passing the test; we did have a decent ride out on the last day, covering things like settling the bike down before going into the corner, holding on the throttle, vanishing point etc, but no mention of countersteering.
I was aware of it, though, and I've found that by being aware that I'm doing it all the time I feel much more in control - e.g. on large roundabouts where there you lean left-right-left in quick succession (no knee down though!). I'm still wary of banking too much (partly because I've got an old bike and I'm still building confidence in its mechanical integrity) but already practising countersteering is helping.
The hardest thing I find is mini roundabouts - my bike's got a sharpish clutch and is jerky even in 2nd and 3rd, so I put on a good newbie show going round those!
PostPosted: 12:56 - 15 Jul 2005    Post subject: Reply with quote
I just go straight over the top of them, see how much air I can get Wink
AcIdBuRnZ
PostPosted: 13:03 - 15 Jul 2005    Post subject: Reply with quote
ADVISORY: on dry roads only!!! Laughing
Past: Honda NSR125R >> Kawasaki ER-5a2 >> Kawasaki ZZR-600e1 >> Suzuki GSXR-750Y >> Honda VTR 1000 Firestorm
"Chickity China the Chinese Chicken..."
DEN MONKEY
PostPosted: 13:13 - 15 Jul 2005    Post subject: Reply with quote
Just something to consider also, is that once you have the new tyre put on the back take it easy on it before trying to lay it straight over. They tend to be a tad "slippery" for the first 50 miles or so.
Maybe do a search on here about the subject, there's plenty of helpful info on it.
PostPosted: 14:09 - 15 Jul 2005    Post subject: Reply with quote
Eh?
Never heard that before Neutral
Surely pulling on the outside bar has the same effect as pushing on the inside bar?
If I need to really shift a bike (ie leaning at serious speeds) I use both.
Now, when hanging off or leaning your body over, your outer hand naturally pulls the outer bar in a bit and your inner hand pushs that bar out a bit thanks to body position - which is why people often presume leaning off a bike actually makes the bike turn (which it doesn't significantly).
PostPosted: 14:14 - 15 Jul 2005    Post subject: Reply with quote
Got Pirellis
If you want faith in your tyres then a good suggestion might be to ride to Reading, and get G to get his knee down on your bike.
This will make you believe in your machinery! Smile
Alternatively you could get someone who isn't likely to try elbow down! Smile
[edit] I am actually being vaguely serious, I've seen G touch his elbow down on the RS250 on squared off tyres. The pics are available somewhere, probably on Bendys site. Additionally I found it helpful when my instructor told me that there is actually /more/ rubber on the road when you are cornering than when you are going in a straight line, and hence you should grip /better/ in the corners! [edit]
Delbwoy
PostPosted: 14:45 - 15 Jul 2005    Post subject: Reply with quote
Good thread!
I was well pleased when I learnt about counter steering (From this forum!) and tried it out. Helps massively when I go into a bend too fast and my heart starts beating that bit faster. Just push away accordingly and round I go. Loving it!
I get scared too when leaning. The thought is there at the front of my mind " Are these tyres gonna hang on?" and then "How low can I go?"
I think track days are going to be the solution to get over the fear. Get taught properly with marshals etc to help if things go a bit wrong. Also no pedestrians/traffic to cause concern.
That's all in the distant future now as I can't ride my bike as of yesterday. I'll post about that.
Good luck all.
Check my website. look at my profile though as putting it here would be spamming methinks (I worked hard to create it so at least look at it!) Nothing to do with bikes I might add! Might appeal to the more feminine personality.
steveh
PostPosted: 16:31 - 15 Jul 2005    Post subject: Reply with quote
good read Thumbs Up
I haven't been around for a while, Tiscali isp was ripping us off, anyway going to get some clothes on and go out and give this a bash, ill let you know when it all goes pear-shaped and i end up eating tarmac Smile
Steve.
The last post was made 20 years, 311 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 2.04 - MySQL Queries: 13 - Page Size: 129.07 Kb
