john0207 |
john0207 Derestricted Danger
Kickstart |
Kickstart The Oracle
Posted: 17:37 - 15 Jul 2005 Post subject: |
The RS is all metric. Forget any imperial sockets. Cannot remember what size it is, but either 11, 12 or 13. Mildly fiddly to do, but not that bad.
Those nuts holding the barrel to the bottom end do not need to be that tight and do not need thread lock. You do need to use a new gasket and you do need to clean the remains of the old gasket away thoroughly (and being careful not to scratch the mating surfaces).
Suspect that you might have had the cooling system drain into the crankcases. How old a model of RS is it?
john0207 |
Kickstart |
Posted: 18:55 - 15 Jul 2005 Post subject: |
Highly unlikely the loose bolts are all the problem. They might allow water to leak out or air to leak in, but neither on there own would be a major problem. However water leaking into the crankcases and filling them up would be a problem.
Right, 123 engine. That makes things easy.
Take off the fairing on the right. Look under the engine, just in front of the starter motor. You should find an allen key bolt. This is to cover a hole used for setting the ignition timing, but is useful to drain the crankcases. Undo this and see if you get a load of water coming out.
Put the bolt back in before attempting to start the engine.
john0207 |
Kickstart |
Posted: 19:24 - 15 Jul 2005 Post subject: |
You really need to know why it is no longer running. However a water leak from the gasket would only really cause a problem by draining into the engine (assuming the last time it was running it did not run out of water and nip up).
Check the water first (easy check). Then check things, such as whether you have a spark.
Those nuts holding the barrel on should be done up to 30Nm.
john0207 |
Kickstart |
ZRX61 |
ZRX61 Victor Meldrew
The last post was made 18 years, 300 days ago. Instead of replying here, would creating a new thread be more useful? |
