instigator |
instigator Super Spammer
Posted: 14:24 - 19 Jul 2005 Post subject: Commonly used Practise |
Looking to replace fork seals, springs and oil in the next 2 weeks.
Just one question before I do so:
What do I rest the front end/engine on
You obviously can't use a front paddock stand...and the exhaust runs under the engine with the frame above the engine. So how do I rest the bike onto somehting to keep it stable?
I'd assume the exhaust would not be a good place to rest the bikes mass on! |
mr.z |
mr.z World Chat Champion
Posted: 14:57 - 19 Jul 2005 Post subject: |
Take the exhaust off
Provided the nuts aren't seized then it will take no more than 15minutes to take them off and put them back (you will need new crush washers though at £1each probably)
If it has a centerstand you can use something heavy to hold the back down and raise the front, ideally use ratchet ties (you obviously dont want anything falling off or you'll have a knackered front end and possibly bent frame...)
You could use scafolding to hang it from and allsorts of other tricks, but a padock stand/center at the rear and jack under the engine block is probably the best bet.. ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
bish777 |
bish777 World Chat Champion
dibbster |
dibbster Nearly there...
Ste |
Ste Not Work Safe
instigator |
Posted: 15:33 - 19 Jul 2005 Post subject: |
Top man Stevey. However....I can say, £88 for a stand is just to much, full stop. I'd consider hiring one but no chance would I find a place that hires them out.
When trying to remove the exhaust, one of the bolts did indeed break off...so I can firmly say, it's stuck on there. So, no....exhaust can't come off
One fork at a time? (yes, I was joking...) |
Annabella |
Annabella Like a person, only smaller
Posted: 15:36 - 19 Jul 2005 Post subject: |
Use two car ramps standing upright, and rest a metal bar with a bolt through the middle (to go up into the yoke) between the two.
Lift the bike up with a car jack under the downpipes slide the bar through, then gently lower the bike down onto the bar.
Used this method a few times, and never had a problem. ____________________ Avast! Pirates ahoy!
I did Cadwell!
www.bikepics.com/members/bella |
instigator |
Posted: 15:40 - 19 Jul 2005 Post subject: |
Hmm....thats an interesting one bella. Don't suppose you took a picture of your bike on this contraption, did you? I'll get the car ramps out tonight in this case and see if it can be done. |
dibbster |
Posted: 16:07 - 19 Jul 2005 Post subject: |
Two wheely bins? ____________________ Suzuki RF 600 - The two wheeled Testarossa (Deceased)
Suzuki GSXR - Now stops on a sixpence; SBK3's
www.bikepics.com/members/dibbster |
Method |
Method World Chat Champion
Posted: 19:32 - 19 Jul 2005 Post subject: |
ZRX61 |
ZRX61 Victor Meldrew
Posted: 19:42 - 19 Jul 2005 Post subject: Re: Commonly used Practise |
BlackSheep |
BlackSheep Trackday Trickster
Bezzer |
Bezzer World Chat Champion
instigator |
Posted: 10:54 - 20 Jul 2005 Post subject: |
zrx61 - How much did that stand cost? OT: Bike looks lovely...
The hornet doesn't have a centre stand as standard but I'll be buying one. There's one on ebay at the moment.
Been told by others on the hornets nest that they let the bike rest on the downpipes. I would have thought that would be bad practise, putting too much stress on the joins on the engine block and connecting bracket underneath the bike. I was looking at one of those paddock stands that support it at the headstock, but £88 is crazy money.
Appreciate all the feedback folks. |
Annabella |
Posted: 12:14 - 20 Jul 2005 Post subject: |
Gazdaman |
Gazdaman I did a trackday!!!
Guest |
Guest Brolly Dolly
ZRX61 |
The last post was made 18 years, 291 days ago. Instead of replying here, would creating a new thread be more useful? |
