Aftermarket indicators
matty8887
PostPosted: 15:13 - 10 Aug 2005    Post subject: Aftermarket indicators Reply with quote
HI all, i am buying some aftermarket indicators for my rs125 for the fornt and back and would just like to know if these would fit with no modification needed? https://cgi.ebay.co.uk/Mini-Motorcycle-Indicators-ARROWshape-carbon-blackNEW_W0QQitemZ7991432443QQcategoryZ9946QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
They are universal but will they go onto the back ok?
cheers
PostPosted: 16:09 - 10 Aug 2005    Post subject: Reply with quote
Depends on the size of the indicator stalk on those, and that you cannot really see in the picture.
Anyone else not seen a Halogen indicator bulb before?
Metal_Mickey
PostPosted: 16:28 - 10 Aug 2005    Post subject: Reply with quote
The chances are that you will need some of the Motrax (assuming the indicators are also made by Motrax) indicator spacers as well. This is because the original indicators tend to be a bit large and leave an unpleasant hole when they are removed, so the spacers cover up this hole and make the new indicators a bit more pleasing on the eye.
matty8887
PostPosted: 17:42 - 10 Aug 2005    Post subject: Reply with quote
Hi, it says they can be bought with a long or short stem, would i have to buy the long stem?
Metal mickey, i do have one arrow indicator and it does look ok so i think they should look good.
Do you know if they just go straight on at the back aswell because they attach to the reg bracket.
cheers guys
PostPosted: 18:00 - 10 Aug 2005    Post subject: Reply with quote
Think the Aprilia ones have a small hooked bracket and then an M6 bolt. These might just go through the hole the bolt currently uses, but will leave the slot that the hooked bit goes through. Probably not noticeable.
dransy
PostPosted: 18:05 - 10 Aug 2005    Post subject: Reply with quote
they look like the ones i have on my rs except mine have iridum lense not orange
The last post was made 20 years, 240 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 2.06 - MySQL Queries: 14 - Page Size: 48.9 Kb
