brakes squeaky after wheel removal
White Noise
Mr Dudwee
PostPosted: 22:58 - 20 Aug 2005    Post subject: brakes squeaky after wheel removal Reply with quote
today i took both wheels off the bike to get the tyres changed, put the wheels back on fine and went for a ride, then noticed that on braking at low speeds the front brakes are squeaking, and they weren't before the wheels where removed
not sure why they are as the only things that i can think if is the pads may have moved out of there original siting position on the pistons and the caliper mounting bolts have been removed. i have tighted the mounting bolts as much as i can but still there is a squeak, next step it reapply copper grease to the back of the pads. if this doesn't cure it i'm at a loss! any one got any ideas what else it could be?
WN
PostPosted: 23:21 - 20 Aug 2005    Post subject: Reply with quote
Give everything a good clean. Brake dust can trigger the squeak. Also copper grease on the back of the pads.
The last post was made 21 years, 50 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.38 - MySQL Queries: 14 - Page Size: 32.58 Kb
