 killa Won't Shut Up
 Posted: 11:08 - 23 Aug 2005 Post subject: Annoying |
After riding the VFR for a while now I have noticed that the tank needs to be topped up regularly, the shape maybe of the tank or maybe the way the fuel enters the tap can’t be brilliant. Say for example I fill it up, say 7 pounds worth maybe more, the ride is smooth in acceleration and corners etc, then it gets to reserve, you should get a fair few miles with no problems when switched over but as the fuel floats around reserve and normal I loose some power, it gets gradually worse so I have to top up. This means there is a good amount of fuel in there I never use and I need to refill to get that kind of ride again.
Anyone else have this problem or similar, I thought if you don’t I might have some crap in the tank or something. ____________________ Cleverly disguised as a responsible adult.
Bike:- Yamaha TRX850 | Killas Biking History | Killas Gaming History | Killas autmotive history |
 Suzuki Roger
 Posted: 11:19 - 23 Aug 2005 Post subject: |
Sounds like you have some debris in your reserve pipe.
My ZXR performed the same on reserve as it did on normal. ____________________ <Simple> no I'm shaven Jon
<Simple> it is a big enough hole.. I'll leave it now
Ride: 1999 Suzuki GSXR600 (yellow/black) IRC: Stats - Relationship Map |
 Kickstart The Oracle
 map Mr Calendar
 Posted: 11:33 - 23 Aug 2005 Post subject: |
Trick to clean any rust out of the tank is to use car radiator cleaner.
Put some in the tank with hot water (from kettle). Put cap on tank and shake around. This turns the rust into solution which can be poured out. Shake out the crud and then rise out with meths. This will absorb the water left in the tank. As said clean out the tap and tube and then put back together.
I'd also run it with a petrol additive for the first few fills (e.g. Silkolene FST Pro). ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
