minirock000 L Plate Warrior
mr.z World Chat Champion
Posted: 11:59 - 29 Aug 2005 Post subject: |
Are you sure you dont need a new thermostat? Check that first..
If your radiator needs replaceing it will cost you a similar ammount to have one refurbished, theres many radiator specialists will rebuild it for you...
Otherwise your best bet is a breakers.
The knocking, this isn't a good sign.. try useing some optimax and see if it dissapears... it could be one of a few things.. if it is "knocking" then your going to be spending allot of money getting it fixed (too much).
If you stuggle fixing these easyly then to be perfectly honest your going to be better off cuting your losses, brakeing the bike and moveing on..
EDIT: Duh (looked again)... If its running hot the knocking/pre-ignition, is a symptom of running hot, if you try useing optimax it might fix it till you can sort the rad ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
