speedo backlight
kwellsqpr1
PostPosted: 01:44 - 07 Sep 2007    Post subject: speedo backlight Reply with quote
i dont think ive had a bcaklight on my speedo on a gilera smt50 for ages. dont eve know if i had it when i bought it brand new. how would i change a bulb if its gone? and i should have 1 yes?
keeping it rubber side down
konsoli
PostPosted: 01:50 - 07 Sep 2007    Post subject: Reply with quote
It should be a case of, take the top front panel off with screwdrivers or alan keys, whatever.
Stand back, look at wiring, and go "Hmmm, electricity.".
Then take the bulb out and put a new one in, make sure you re-connect any connections you may have broken while playing with this.
When I was fixing my speedo, lost use of all my lights, had to re-strip front to rig it up again. It worked fine after, just need to check before you put it back together
kwellsqpr1
PostPosted: 01:52 - 07 Sep 2007    Post subject: Reply with quote
do you no how to get the front of my bike lol. its a rubber mounted thing dont have a clue
konsoli
PostPosted: 02:17 - 07 Sep 2007    Post subject: Reply with quote
Hmmph.
Just checked a pic of your bike out though, the fairing between the indicators, above it. Look around that for any bolts. Should be a couple. Look from underneath on both ends, you may find them there.
EDIT: Just checked a bigger pic, are there 2 alan key bolts at the top of the forks? You may need to remove them, remember where everything goes though.
Also, does your bike resemble this one in any way, shape or form?
https://www.bikebros.co.jp/images/wallpaper/gilera/smt50_1024.jpg
kwellsqpr1
PostPosted: 02:29 - 07 Sep 2007    Post subject: Reply with quote
yea thats the bike. thanks for the help i remember seeing some screws near the front now ill have a lok tomorrow. thanks
konsoli
PostPosted: 03:36 - 07 Sep 2007    Post subject: Reply with quote
no problem, just make sure you can get it back together easy.
When you get that bit off, don't try to take the fairing off, as there will be a lot of wiring attached to pieces inside of it. Just rest it slightly out on another bit. a few inches.
Rip the old bulb out the speedo, if in doubt, take that one to a garage or shop. get a new one, shove it in. back together.
good luck
Finglonga
PostPosted: 09:39 - 07 Sep 2007    Post subject: Reply with quote
Use an LED, you will never have to worry about it again. Wink
Andy Sez....
F.Y.Y.F.F.
konsoli
PostPosted: 13:43 - 08 Sep 2007    Post subject: Reply with quote
Any update, kwellsqpr1?
The last post was made 19 years, 31 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.47 - MySQL Queries: 14 - Page Size: 54.77 Kb
