*URGENT* Datatool Alarm Help Needed *URGENT*
Paracaine
PostPosted: 14:06 - 20 Sep 2005    Post subject: *URGENT* Datatool Alarm Help Needed *URGENT* Reply with quote
Hi, I have a Datatool System 3 alarm on my Bandit and I am having major problems.
Me and my dad are trying to fix it, here are the symptons -
- After alarm activates when key removed from ignition (double beep) the alarm goes off nearly straight away.
- The indicators do not flash when the alarm is activated/deactivated and they do not flash when the alarm goes off
- The bike is totally imobilised even when the button is pressed and the key is inserted in the ignition.
We have tried -
- Replacing the inline fuse.
- Letting the alarm go off fully for 30 seconds.
- Making sure it wasn't in sleep mode.
- Pressing the buttons to disarm it!
I cannot use the bike untill this is fixed and the bike is my only form of transportation, please help!
Thanks, Ed.
Bike: Suzuki Bandit 600, 2002, Blue
Type: Unfaired
Extras: Datatool Alarm & Immobiliser, Airblade Tinted Fly Screen, Motrax Crash Protectors
PostPosted: 14:18 - 20 Sep 2005    Post subject: Re: *URGENT* Datatool Alarm Help Needed *URGENT* Reply with quote
No help I'm afraid:
As Datatool's are fitten by an 'official' center, people don't generally get to know how they're wired.
Might be worth googling for them and seeing if there's an offical service place near you that can help.
Paracaine
PostPosted: 14:19 - 20 Sep 2005    Post subject: Reply with quote
A garage near(ish) to me does them but I can't really afford to pay anyone Sad
Type: Unfaired
Mr.Everready
PostPosted: 14:20 - 20 Sep 2005    Post subject: Reply with quote
Contact Datatool on 0870 165 2414 and talk to a technician.
Bendy
Mrs Sensible
PostPosted: 15:12 - 20 Sep 2005    Post subject: Reply with quote
Did you set the PIN number when you got it?
There's some convaluted way of starting it using the fuse and the ignition, based around the pin number... might be worth a try.
Have you tried the other alarm fob?
sickpup
Old Timer
PostPosted: 15:54 - 20 Sep 2005    Post subject: Reply with quote
does the alarm react to the key fob?
The alarm can be set so the indicators don't flash, did they ever flash?
If they did you either have a dodgy positive or earth connection to the alarm unit.
Paracaine
PostPosted: 16:21 - 20 Sep 2005    Post subject: Reply with quote
Yes, the did used to flash.
I am doing a full reset at the moment anyway, disconnected the alarm and leaving it for 6 hours.
Type: Unfaired
sickpup
Old Timer
PostPosted: 16:24 - 20 Sep 2005    Post subject: Reply with quote
Won't work as it's not the problem.
It will take more than 6 hours to drain the internal battery and the problem is the power supply to the alarm as when it doesn't have one the indicators don't flash.
Paracaine
PostPosted: 16:49 - 20 Sep 2005    Post subject: Reply with quote
What can I do then? (Besides taking it to a dealer)
Type: Unfaired
sickpup
Old Timer
PostPosted: 17:10 - 20 Sep 2005    Post subject: Reply with quote
Check the power connections to the alarm. Is the fuse getting power?
If not it's the earth from the alarm to the frame.
Paracaine
PostPosted: 17:12 - 20 Sep 2005    Post subject: Reply with quote
I am not too handy on a Volt meter so I will get my bro to help when he gets back.
Do you know where the alarm earths to the frame?
Thanks
Type: Unfaired
sickpup
Old Timer
PostPosted: 17:13 - 20 Sep 2005    Post subject: Reply with quote
No, depends on the fitter but normally near the alarm box.
Paracaine
PostPosted: 17:18 - 20 Sep 2005    Post subject: Reply with quote
Thanks, you have been a great help.
I will get my brother to have a look at it with me later.
Type: Unfaired
The last post was made 21 years, 38 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 78.03 Kb
