Overheating tyres pos???
Claud 14.7 to 1
PostPosted: 20:26 - 24 Sep 2005    Post subject: Overheating tyres pos??? Reply with quote
Went for a spin today, and had a little slippsie (not an off).
On the side of the tyre in question, it looked glazed, and was "tacky" to the touch.
Does this mean the tyre was overheating or something? It wasn't even a hot day. Confused I thought it bubbled up when they overheated.
Don't want it doing that again. Thanks.
PostPosted: 20:29 - 24 Sep 2005    Post subject: Re: Overheating tyres pos??? Reply with quote
Could the patch in question not be an effect rather than a cause of the slide?
Claud 14.7 to 1
PostPosted: 20:33 - 24 Sep 2005    Post subject: Reply with quote
It wasn't a patch, this texture was all the way round both tyres. It did kinda feel as if it wouldn't be as "grippy" somehow.
PostPosted: 20:37 - 24 Sep 2005    Post subject: Reply with quote
Very much doubt you would get anywhere near overheating a tyre seriously on the road.
My guess would be that you have ridden through something, or something from the bike. Chain lube (quite tacky), tyre slime, something like that.
Claud 14.7 to 1
PostPosted: 20:50 - 24 Sep 2005    Post subject: Reply with quote
Hmmm it felt like the tyre was "melting". Not as if something had become stuck to it.
Maybe it's because they are sports/commuter tyres. Not sure. I am sure I've had the same texture on the front end and it's let go momentarily a few times.
O well. Summer's just about over now anyway, hehe.
gavin
PostPosted: 21:27 - 24 Sep 2005    Post subject: Reply with quote
you can heat up a tire too much, if your suspension isnt good and you are pushing it, on small bikes this is easy to do as the suspension is usually crap anyway, and with light weight and easy flickability, you dont notice a small bikes suspension shortcomings, but you are hardly likely to do this on the road.
the real damage gets done if you allow them to get very hot, then cool down again quickly and dont put heat into them for some time, then ride them hard again. do this and you will soon find them hardening up, and you will notice a blue/green/red sheen on the surface, near the edges. i think this is caused by the oils leching out of the rubber. i sometimes see it on my road bikes if ive been out for a last blast at the end of the summer, then take them out of the garage in the following spring.
you will see lots of part worn trackday tires for sale, with loads of tread, and probably the sheen on the edge. i wouldnt touch them - the people selling them know they have 'gone off' and selling to buy a new set of the same with much more grip.
PostPosted: 21:35 - 24 Sep 2005    Post subject: Reply with quote
Unlikely they would get hot enough to melt, and would rapidly cool down so you would not feel it.
As Gav says, get them too hot and let them cool down and they will go off. Will land up with all the grip of an inner tube.
Claud 14.7 to 1
PostPosted: 10:58 - 25 Sep 2005    Post subject: Reply with quote
OK thanks, I'll keep an eye on it.
Can't have overheated, as in France we were pusing it harder, and it was far far hotter. Wierd though.
Thanks again, Claud. Thumbs Up
palmer
Fiddled Kiddy
PostPosted: 11:59 - 25 Sep 2005    Post subject: Reply with quote
my dads tyres seem to get glazed and tacky when left in the garage for a week or so.
might it be moisture in the air affecting the tyre compound?
Jack_Cheese
PostPosted: 14:50 - 25 Sep 2005    Post subject: Reply with quote
If the chicken strips have a bit of blueness around where they meet the grippy part, then they'll have been overheated.
Jack
www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
EuropeanNC30R...
Gay Hairdresser
PostPosted: 12:40 - 26 Sep 2005    Post subject: Reply with quote
I've had BT010's and all kinds of Dunlops have blue rings around the edges when they've been left a few days without use, thought it was fairly normal.
paulthewitt
PostPosted: 14:51 - 26 Sep 2005    Post subject: Reply with quote
my dunlops (sportmax) also had blueness when left for a couple of days. so may be normal. having said that, i always said they grip as much as a colouring crayon.
Paul
tonyyzf
PostPosted: 08:52 - 27 Sep 2005    Post subject: Reply with quote
I've been riding for 28 years, I've only once had a tyre 'go off' it was on the front of my FZR1000 and blistered.
Usually if you pay decent money for decent tyres you won't have a problem, yes, they will heat and get very sticky feeling, thats how they work, if they didn't you'd fall off, hence the reason racing bikes and cars do a 'warm up' lap, its to get the tyres up to working temperature, why do you think they use tyre warmers?
Some tyres suit some bikes more than others, my Ace was crap with Bridgestones, used to slide on corners but with Metzlers or Dunlops it would stick like glue and give me no worries.
If you ride erratically, accelerating and braking a lot then you will heat the tyres more, creating a loose surface of melting rubber, you sometimes get a slide from this, this is what they mean when they say the tyres 'going off', if you cool it and run it sensibly for a short time it will wear of the loose stuff and return to normal.
The last post was made 20 years, 357 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 76.45 Kb
