 Josh|RD125LC World Chat Champion
 Posted: 17:54 - 30 Sep 2005 Post subject: Air Filter Probs |
Hi,
I had a RamAir filter (foam), fitted onto the RD. I was at first running it with the stock 195 size main jet. But a few days ago, I put in a 210 and it was running very nice. The only problem was that it would flood itself when trying to start.
Anyway,
Today, I fitted the standard airbox, and took off the RamAir as it seemed to bog it down a bit and was crap in damp conditions. So I spent quite a while fitting it, changing carbs over, checking the float height etc, got it all right and fitted it all back on. Took it out for a spin, and the performance was rubbish. It was very slow through the gears when I would go flat out. Takes about 5-6 seconds to reach the powerband at 9000rpm, whereas before it would only take 2-3 seconds. Also, noticed that it is very spluttery through the revs. All the way til 9000 revs, its spluttering, bogging down. So I got home and looked at the carb, and I found that the carb was covered in condensation. Maybe this was nothing to do with the performance, but I am concerned at how sluggish it is now.
I think the problem may be that the bike is getting an uneven mixture of fuel and air, as the jet is now a 210, instead of the stock 195. So it could be that the jet is too big, and it letting in more fuel than air, resulting in it spluttering and bogging down a lot?
Any ideas?
 ____________________ Honda MBX50 | Yamaha RD125LC | Suzuki RG125F Lucky Strike | Suzuki GSF600S
RD125LC Pictures |
 Kickstart The Oracle
 sickpup Old Timer
 Posted: 03:12 - 02 Oct 2005 Post subject: |
It has the airbox on now with the standard 195 size jet.  ____________________ Honda MBX50 | Yamaha RD125LC | Suzuki RG125F Lucky Strike | Suzuki GSF600S
RD125LC Pictures |
