fitting resrictors to a XJ600s
White Noise
Mr Dudwee
PostPosted: 23:26 - 03 Oct 2005    Post subject: fitting resrictors to a XJ600s Reply with quote
i am looking to find some information on how to fit restictors in a XJ600, and what parts are needed (washers). want to find out not to fit them but to find out if my bike is restricted as i have my suspisions that it maybe
WN
dmjar
PostPosted: 18:15 - 04 Oct 2005    Post subject: Reply with quote
Check the Inlet Manifold, there is usually a washer inside. My zzr600 is restricted and that is the only restriction on it. But you have to bear in mind the diversion is not the quickest bike in the world.
bish777
PostPosted: 18:41 - 04 Oct 2005    Post subject: Reply with quote
Take off the fuel tank, air box and then the carburettors.
Look into the rubber inlet manifolds for washers.
Divvy 600s arent fast but theyre not slow either. It should crack teh ton easily and top out at 115 or so.
GSXR1100J
White Noise
Mr Dudwee
PostPosted: 18:57 - 04 Oct 2005    Post subject: Reply with quote
is that indicated or true?
cheers for the replys will take a look
WN
JeffT
PostPosted: 20:57 - 04 Oct 2005    Post subject: Reply with quote
well my divvy 600 does an indicated 120-125 top end so i reckon a 110-115 true isn't out of the question.
The last post was made 21 years, 4 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.73 - MySQL Queries: 16 - Page Size: 43.67 Kb
