keeps cutting out
new boy
PostPosted: 01:33 - 10 Oct 2005    Post subject: keeps cutting out Reply with quote
hi just bought a yamaha fzr 400 and its been stood for 3 years and it starts fine and runs on 4 cylinders revs well but when you try and ride it it just cuts out and when i start it again it only runs on 2 cylinders and before it was parked up it was fine any explination would be great i have changed the spark plugs and leads Thinking
I need help
new boy
PostPosted: 01:58 - 10 Oct 2005    Post subject: just a thought Reply with quote
do they have a side stand switch if so could this be the problem Idea
I need help
PostPosted: 11:14 - 10 Oct 2005    Post subject: Reply with quote
If it has been stood for that long, any fuel that was in the tank will have gone stale. It is also possible that any that was left in the carbs may have turned into gummy stuff that would have blocked up some of the carb jets.
If I was putting a bike back on the road after sitting for three years, I would be draining any fuel out of the tank and replacing it with fresh stuff and carrying out a full service (change oil and filter, clean fuel filter, replace plugs, check air filter, check tappets).
If this still doesn't help, it may be you need to clean out the carbs, it is entirely possible that they are full of detritus.
Another thing that could cause that problem is a blocked tank breather, try running it with the tank cap open.
new boy
PostPosted: 20:49 - 10 Oct 2005    Post subject: Reply with quote
tried most of it except tappets today and changed fuel when i first started it and still no difference its as sweet as a nut just sitting running and as soon as i put the engine under any strain at all eg pulling away it stops then i start it it starts on 2 cylinders then if you leave it for about an hour its fine again it feels like an electrical problem Brick Wall but what do i know im a car mechanic Laughing
I need help
PostPosted: 21:18 - 10 Oct 2005    Post subject: Reply with quote
Always the same two cylinders it is dropping?
If so, try swapping over the coils, if the problem moves to the other two, you found the cause.
Battery in good nick?
new boy
PostPosted: 01:28 - 11 Oct 2005    Post subject: Reply with quote
cheers Thumbs Up will try that as soon as i am allowed to tinker the girlfriend doesnt like that im giving the bike more attention than her Laughing
I need help
The last post was made 20 years, 338 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.45 - MySQL Queries: 15 - Page Size: 48.84 Kb
