requires coils or pick up........
froggy128
PostPosted: 13:52 - 18 Oct 2005    Post subject: requires coils or pick up........ Reply with quote
how much do these cost then its a non runner am looking at
ideas?
PostPosted: 13:57 - 18 Oct 2005    Post subject: Reply with quote
Depends on the bike. Which one is it?
2nd hand they should be fairly cheap on Ebay.
Good chance that only one coil has gone.
froggy128
PostPosted: 15:15 - 18 Oct 2005    Post subject: Reply with quote
where are they located?
map
Mr Calendar
PostPosted: 16:06 - 18 Oct 2005    Post subject: Reply with quote
For coils go to your sparkplug cap and trace the HT lead upwards.
FWIW usually located under the tank, but on smaller bikes maybe the seat area.
Second hand coils from breaker, depending on the bike obviously, I'd expect to be between £10 and £20. Worth checking if connectors for HT leads will be compatible with what you're using.
Don't take this the wrong way but maybe sign up for a basic maintenance course or get some bedtime reading like these:
https://www.haynes.co.uk/wcsstore/HaynesPublishing/images/Bookjackets/150scans/3515.jpg and / or https://www.haynes.co.uk/wcsstore/HaynesPublishing/images/Bookjackets/150scans/4071.jpg
HTH Thumbs Up
PostPosted: 16:58 - 18 Oct 2005    Post subject: Reply with quote
Coils as above.
The pick ups probably are on the side of the engine around the crankshaft. Might be under a crankshaft end cover. There will probably be long wires from these up the to cdi unit.
Which bike is it?
The last post was made 20 years, 253 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2.85 - MySQL Queries: 14 - Page Size: 45.51 Kb
