Reconditioning shocks?
Valver
PostPosted: 22:03 - 18 Oct 2005    Post subject: Reconditioning shocks? Reply with quote
My FZR750 has been bouncing about the road for too long and with winter looming i can't really risk running the bike much longer with the rear shock the way it is. I bought a replacement on ebay last week (very cheap) but it doesn't seem much better.
Where can i send one to be overhauled? Can i do it myself with a kit? Is it expensive? Should i just bit the bullit and buy a new one?
PostPosted: 23:00 - 18 Oct 2005    Post subject: Reply with quote
There are quite a few places around. Such as Revs Racing in Halesowen.
Think a rebuild will be £60~£100 depending on what needs doing (eg, is the damper rod OK).
Valver
PostPosted: 23:12 - 18 Oct 2005    Post subject: Reply with quote
Many thanks Keith!!!!! Thumbs Up
Again!
Joey Bane
PostPosted: 11:21 - 20 Oct 2005    Post subject: Reply with quote
sounds like the spring is £ucked to me
Currently driving: Motorhispania RYZ(yes i'm another ped "boi")
PostPosted: 12:39 - 20 Oct 2005    Post subject: Reply with quote
When springs go they tend to get a bit soft at the initial part of their travel (not really a common problem). When damping goes it just allows the spring to bounce around.
muddycoffee
PostPosted: 17:20 - 20 Oct 2005    Post subject: Reply with quote
It is the same thing but easier to spot on a car. The car will loose it's handling and poise, and will often skip or wallow around corners rather than go around like it's on rails. And believe me it's kind of frightening and can cause skids or loss of traction.
You go to each corner of the car and press the suspension down with both hands and it should smoothly come back to normal height. When the damping has gone, it just rebounds forever and takes ages to settle.
Suzuki SV650 naked Blue curvy with Givi Screen and G force can.
PostPosted: 18:01 - 20 Oct 2005    Post subject: Reply with quote
Trouble is bikes tend to be a lot more sensitive to damping, and some people will have massive problems with the handling long before the shock has blown all its oil out.
Had a few odd problems with shocks. My FZ750 one was working OK but the damping was slightly weak on it so I adjusted it slightly. About 1 mile later I had no damping at all. Its replacement had a horribly sensitive damping adjuster and went from taking 5 seconds to rebound to almost taking my nose off on the rebound with a tiny turn of the adjuster. Old Aprilia AF1 Futura had damping when I went onto a roundabout and resembled Zebedee when I came off the roundabout.
When she shock on the Divvy went I had it rebuilt but it turned out the body was too work. The seals on the piston came out and pretty much jammed the shock.
Can be quite worrying watching car wheels sometimes. It is not that rare to spot a car with a dodgy shock and the wheel bouncing all over the place.
Valver
PostPosted: 18:26 - 20 Oct 2005    Post subject: Reply with quote
The spring has corroded and cracked in places. Its lost about 30mm of seat height in the last few months. The damper makes a crunching sound when you push it hard Laughing
The new one i bought ain't much better but atleast the spring is in better condition.
PostPosted: 19:35 - 20 Oct 2005    Post subject: Reply with quote
Suspect the spring can easily be replaced. Maybe with a nice tarty yellow Ohlins one Laughing .
At least you have a spare one to get rebuilt so the bike is not off the road while it is away.
The last post was made 20 years, 295 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.84 - MySQL Queries: 16 - Page Size: 64.92 Kb
